Results 1 to 8 of 8
Thread: Shock first? Or raise alkalinity?
    Hi. I've almost got everything in order. I'm still reading CC 1.5 so from what I've read I need to shock the pool. Do I do this first? My pH and TA is reading a little low so I was going to add baking soda to the skimmer to raise it. Also, what is bromax for? Do I need to add some to the pool? My readings this evening were FC 7
    CC 1.5
    TA 60
    pH 7.0ish(still hard for me to read)
    I didn't test CYA. Thanks!
    New owner of a 35k gallon IG vinyl pool
    Sand Filter
    Still learning everything else!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Shock first? Or raise alkalinity?
    Borax raises PH. I would leave your PH and TA alone for now, test your CYA and once you know that you can shock the pool. Read How to Shock Your Pool in Pool School - you can't shock properly if you don't know the CYA level.
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Anytime you add the baking soda just add it into the deep end of the pool while the filter is on.
    Bring your cya up to the correct level, shock, and then balance the ph & alk.
    I dnt use borates, but i thought you guys added it to prevent algea not bring up the ph??
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    30,414
    20 Mule Team Borax is the correct additive when you want to raise pH but leave the TA virtually unmoved.
    It is also used in conjunction with muriatic acid when you want to add borates to your pool water.
    These two procedures accomplish different objectives.
    11,969
    Typing in th ecar makes for some intresting spellingmistakes...
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by frustratedpoolmom
    ha!
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    11,969
    finally in the Central time zone...getting closer
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Quote Originally Posted by Heckpools
    The many uses of that modern wonder that is borax...I actually use it in my laundry too. Imagine that!
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
