Results 1 to 12 of 12
Thread: Help with Baq conversion
    Barbara C's Avatar
    Jun 2010
    Southern Indiana
    124
    Started my Baq conversion today. I put in 420 oz. of 6% bleach to get my FC to 15. 1 1/2 hour later my FAS/DPD test showed.....
    1. after 10ml of pool water and one heaping scoop of powder sample didn't turn pink but possibly the slightest hint of pink
    2. as I continued to add drops the sample became more and more pink with each drop
    I was confused by this and stopped the test at about 30 drops.
    3. Repeated the test and got identical results.
    4. OTO test shows 0 chlorine.
    I assume I have 0 chlorine but I don't understand why FAS/DPD test progressed towards pink as i added drops.
    Thanks for any help!!!
    24' AG Vinyl
    13,500 gallons
    1hp Hayward pump
    Sand filter
    Jug dumper apprentice
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Help with Baq conversion
    I'm guessing that it's CC interference and the FC was very low/nil. Which drops were you adding?
    If the yellow OTO shows 0 then it's zero
    Good luck we're here to assist!
    Barbara C's Avatar
    Jun 2010
    Southern Indiana
    124
    Added the R-871 drops. Sounds good!
    24' AG Vinyl
    13,500 gallons
    1hp Hayward pump
    Sand filter
    11,969
    Try adding some more bleach and testing within 30 minutes with the OTO. If you see Yellow, the test with the FAS-DPD test. If you add a scoop, and it doesn't turn pink, add another scoop.
    Chlorine gets used up extremely quickly at the start of a baquacil conversion, so the zero FC level doesn't surprise me.
    30,415
    I spoke with Barbara_C on the phone about her test results. I completely agree that the FC could've been used within that time frame.
    What puzzles me is, after the DPD Powder was added, each succesive drop of R-0871 produced a steady increase towards a rosy pink in the solution until she stopped at 30 drops.
    I have never heard that reported nor am I aware of any interference that would cause that response.
    OP is redoing FC addition and will test within 30 minutes of dosage with the FAS/DPD.
    11,969
    That's why I thought maybe she was using the wrong drops...
    30,415
    Perhaps adding to the confusion......
    OP has reported that continuing into the CC's test, the solution turns a deep rosy pink immediately upon addition of 5 drops of R-0003. After 5 drops of R-0871, the solution turns completely clear.
    11,969
    0 FC CC 2.5?
    Barbara C's Avatar
    Jun 2010
    Southern Indiana
    124
    I'm afraid I'm adding another variable to the equation.
    The filter needed to be backwashed due to low pressure. I now need to add fresh tap water. That should help it would seem. We'll see.
    24' AG Vinyl
    13,500 gallons
    1hp Hayward pump
    Sand filter
    11,969
    Hang in there!
    Barbara C's Avatar
    Jun 2010
    Southern Indiana
    124
    I didn't take chemistry in school so now I'm getting a crash course! It's all good.
    24' AG Vinyl
    13,500 gallons
    1hp Hayward pump
    Sand filter
