Thread: Aerating
    Jun 2010
    Richmond, Virginia
    12
    Aerating
    Just read the "how to lower total alkalinity" article and I was wondering what suffices for breaking the surface of the water using the return line for aerating purposes? Does it have to actually shoot up out of the water or is the bubbling good enough?
    Pool size: 30,000 gallons
    Filter: Sand, Triton II TR-100
    Filtration flow rate: 74 gpm
    Pool: IG
    Type: Plaster
    Pump: Emerson, 2HP
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Aerating
    Bubbling is good enough, but many smaller bubbles is better than larger bubbles. For example, an air compressor hose put in the water is not great.
    If you search around the site there are many examples of home made aerators.
    You can get cheap fountains that would work too (like this one).
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Re: Aerating
    Must I share?
    Ok. You talked me into it...
    Sub-pump in pool. Hose attached. Sprinkler attached to hose and pointing at the surface. 'Country fountain'
    Worked for us. Cash expenditure= $0. All materials on hand.
    One of my proudest newbie TFPer moments.
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Aerating
    Nice one Chris...reminds me of my redneck solar heater...a submersible pump and a couple hundred feet of coiled up hose and irrigation tubing. Cash expenditure= $0. All materials on hand.
