Results 1 to 8 of 8
Thread: What to do with old sand?
    When you change your sand in your filter, how do you dispose of the old sand? My trashman would not appreciate 150lbs of sand in the can.
    24' Round 14K Gallons
    Hayward S180t Sand Filter
    1hp Hayward Powerflo Matrix Pump
    Aquabot Pool Rover Jr.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Re: What to do with old sand?
    I put it in my horseshoe pits!
    You could make a lot of candle holders, ashtrays? keep a bucket by the fireplace/woodstove in case of emergency, build a beach! The possibilities are endless.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    I could use some for the firepit I guess. Thats a great idea. Any others?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Fill low spots in your lawn?
    I was thinking of using it in the lawn. I could hide it in a planting bed.
    Jul 2009
    Seattle
    87
    Offer it for free on craigslist. Unless you just converted from Baqua it should be fine for a sand box or the low spots in someone's yard.
    20,000 Gallon kidney sort of a sand filtered gunite in ground pool w/ hot tub.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    I brought mine TO the beach
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    Quote Originally Posted by stavs
    Exactly what I did when I replaced mine. Killed the weeds rather well. Let it sit on top over the fall and into the winter then turned it into the topsoil.
    13,100 gal (?) IG Plaster Pool, Rectangular (30 feet long, 11 feet wide at 3 feet deep shallow end, 14 feet wide at 6 feet deep end.)
    Pentair Challenger 1hp 2 speed hardwired pump
    Triton II T60 sand filter
    P153 Intermatic digital timer control
    8 gal Liquidator with 3/8" upgrade
