Thread: Still leaking at seal plate after replace head gasket help
    I have a leak around the seal plate, I replaced it with a new head gasket but still leaks. I can see water leaking from the top of the seal plate. Should I replace the shaft seal or just lub the head gasket with sealant? I have a hayward super II. Thanks.
    16' x 32' IG plaster, 21k gallons
    Hayward 1 hp Super Pump
    Hayward S244T sand filter
    22,553
    Re: Still leaking at seal plate after replace head gasket help
    If you didn't replace the shaft seal when you had it apart it would be a good idea to replace it. Be sure to lube the seal good and the gasket while you're at it.
