Results 1 to 7 of 7
Thread: psi gauge
    Aug 2008
    Rochester, NY
    51
    psi gauge
    I recently replaced one junk psi gauge with another sold by a local pool store. The new one doesn't move higher than 2psi from the pressure immediately after backwashing (20-22 psi). A week or 2 later the gauge reads 2psi higher but i notice a substantial flow decrease out of the returns. Can someone recommend a decent brand or vendor? It needs to be a back mount and the only ones i have found at Lowes/Home depot are all bottom mount. I don't mind paying a little more for quality. It's a pentair sand dollar BTW.
    20000 gal IG freeform, vinyl, Pentair Sand Dollar filter, Pentair 2 speed pump, Pentair Intellitouch controller, Pentair Heat Pump. Built 2008
    22,551
    Re: psi gauge
    Go to Ebay and buy a 0-30psi gauge. They're not much better but the scale is lower so they tend to be more accurate. You could buy a 4" faced gauge but they're expensive for this application.
    You can buy a bottom mount gauge and a 90º elbow and close nipple to mount it to your filter.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Aug 2008
    Rochester, NY
    51
    Re: psi gauge
    Thanks for the reply. So a 90 is okay? I was concerned that the 90 would affect the readings, but wasn't sure if it made a difference.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: psi gauge
    Just make sure you get a sealed gauge. Some of the cheap ones on Ebay and an open back and water can get into the dial.
    Mark
    dremin2flyhi's Avatar
    Jun 2010
    Darlington, SC
    121
    Re: psi gauge
    i picked up a Wika glycerin filled low press 0-30 psi off of ebay for like 25 bucks.... had it 3 years now and still going strong... It is a nice stainless gauge and stands up the elements here very well.. We use these gauges where I work and they are very reliable.
    24' x52" Sharkline Venture (May 2016) ABG (13,500)
    Hayward S180T15932S --Sand filter/ Flo-Matrix pump pack
    Aquatrol-RJ SWG-- Nitelighter NLMC
    Dolphin E10
    Duraspa G2- Premium hot tub --Rotomold style
    Backglass's Avatar
    Jun 2007
    Putnam County, NY
    139
    Re: psi gauge
    Quote Originally Posted by dremin2flyhi
    I can vouch for the Wika guage as well. Just got one from these guys: http://www.gaugestore.com after multiple cheapos over the years. They have back mount versions like you want too. I went all stainless steel and glycerin filled and couldn't be happier. I also went with 0-30 for more granularity.
    These are industrial gauges and they feel like it.
    Aug 2008
    Rochester, NY
    51
    Re: psi gauge
    Quote Originally Posted by Backglass
    Yep. That is where i got it. Very impressed. Shipped it the afternoon i ordered it and received it 2 days later. Good company.
