Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Seems like Im using a lot of bleech
    I have been messing with cya trying to not use as much bleach. I raised cya from 40 to 60 and seems like im using more bleach now than before. I had to ad 61oz of bleach tonight and 57oz last night to around 4000 to 4500 gallons of water. that seems like alot to me.. I thought i was using alot when I was at 40 cya and I was averaging around 50oz's a day. i will raise fc to 9 and be at like 2 at night. I have done a drop test and been with in .5 everytime. I would get it to 7fc at old cya of 40 and only drop down to 1.5 or 1 fc and now at higher starting point fc im dropping to the same. is this normal or what. seems like im using alot of bleach.
    Intex Easy set 18x48 pool
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    South Central NJ
    3,192
    Re: Seems like Im using a lot of bleech
    How about some complete chem levels first.
    What brand of bleach?
    Scott
    Owner of - PoolGuyNJ LLC
    walmart brand cheap bleach. 6 percent
    these are my numbers as of last night just fc and ph. tested all others sunday night
    fc- 2 put enough bleach to get to 9 so that i would be at the high end with my cya.
    cc-.5 always been that. did drop test earlier in the week as well and only lost .5 fc
    ph- 7.5
    ta- 130
    ch-140
    cya- 50, but just added stabalizer to get to 60 few days ago so not reading it yet.
    Its a intex easy set pool that has roughly 4200 gallons with 1500gal pump and filter that came with it. The pool is in direct sunlight all day so Im sure that has some to do with it, not to mention 3 or 4 kids playing in it 4 or 5 hours a day. water looks good, just seems like im using alot of bleach. I do know im going to get a swg next year or maybe even this year.
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I just want to clarify - you are not losing any at night? maybe just .5 or so?
    only lost .5 fc at night. I just tested fc and cc just to see how much I have lost through half day and no one in it. I was at 8fc and .5cc. Was at 9fc last night so far only lost 1fc, but no swimmers and this is the hottest part of the day so I will check again after work. May just be all the dirty kids using all my fc. LOL
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    11,969
    Quite possibly just re-emphasize the no "p" in the "ool" rule
    so my number seem normal?
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    11,969
    no overnight loss is normal, yes - so you're within the acceptable range.
    Do me a favor - about an hour or two after your nightly bleach addition, test the FC to verify you're actually reaching your target. Use that as your comparison for the morning test (assuming you didn't already do this?)
    i have done it before, but not lately. i will do that tonight. I usually dont get the morning test till a hour or so after sun up due to not being a morning person. Is that a big deal?
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    11,969
    Just this once? You can do it... LOL
    It can affect things - lets just.... a) confirm you are actually reaching your target (ie: weak bleach) and b) rule out organic consumption (so we have to take the sun out of the equasion.)
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Quote Originally Posted by pitmanr2003
    Could be. I'm committed now to doing the overnite test after dark and before light thanks to Bama Rambler convincing me to do so. So it was an early morning for this girl today...but sometimes you should see the sunrise in your own backyard. Sets the tone for the whole day...
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    I will try to do it before sun up tomorrow. But correct me if im wrong. If I only have 0.5 fc loss 2 hours after sun up wouldn't that be good. Cause it just would ofbeen less of aloss if I took it earlier
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    I can follow that logic. I'd still rather see a zero myself...lol.
    ok only had 3 swimmers tonight and only for 30min. a little better tonight it was a 3. going to adjust to 9 and recheck in hour or so and try to get up early.
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    ok 2 hours after adding bleach and I over shot my target by a little. I was shooting for 9 and got a 10.5. I will see where I stand in the morning and give an update.
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    ok i made it up. it is a 10 now so it dropped 0.5 which i thought is ok. Just my luck the first time I make it up before sunrise and it starts raining. It only rained for a few mins before I checked it, so i dont think that would of affected it. It was just drizziling also.
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    What you are describing sure sounds like not enough CYA. Are you confident in your readings?
    Pretty confidant. I am using tf-100 and I have checked it several times. Tomorrow will be a week since I added cya to raise from 40 to 60 so I should be able to check again and see result
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    11,969
    You passed
    Make sure when you do the CYA test you do it outdoors in bright sunlight, with your back to the sun to shade the view tube which you hold at your waist level in front of you.
    Add the water to the bottom of the label, add the solution to the top of the label. Shake to mix. Let it sit for 30 secs or so, and then mix it again for another 30 seconds and then pour it in the view tube.
    Here are photos from the Taylor site:
    http://www.taylortechnologies.com/Ch...P?ContentID=44
    That show what the complete test looks like.
  20. Back To Top    #20
    22,543
    Good for you on getting up early. A loss of .5 FC is fine. The rain could have affected it that .5 so I wouldn't worry about it.
    Unless you have a SWCG and I missed it a CYA of 60 is about as high as I would recommend. With that small of a pool a few bathers make more of a difference than the same amount would in a larger pool, however the sunlight should burn up about the same amount of ppm loss. So even though it may seem like you're losing a lot so do we when there are a lot of people in the pool.
