Results 1 to 17 of 17
Thread: 5 day old pool
    Lincoln, NE
    17
    5 day old pool
    Hello to All. New owner, many questions. Have been reading this site for awhile at the suggestion of CREK (site member). Opened my new pool with her help (God love her) and the SHOCK and ANGER of another friend who goes by the pool store method. Here are my numbers:
    FC 6.0
    CC .5
    TC 6.5
    PH 7.5
    TA 170 (was 220)
    Added stabilizer two days ago, so have not yet tested CYA. Where am I and what should I be doing now?
    Thanks and love the site!
    24' x 52" AGP Garden Leisure, 13500 gal, 1 1/2 hp Hayward pump/sand filter.
    Re: 5 day old pool
    Welcome Mokenews!!! So glad to have a recruit! I do want the experts chiming in to be sure you are where you want to be (I've explained I can only be trusted on my own tiny pool) -- as I recall you added 6 to 6.5 cups of stabilizer on Saturday, which likely puts your CYA at about 25. We were figuring 14,400 gallons but based on further reading your pool is probably 13,500 (which I think you told me to begin with).
    Please confirm the amount of stabilizer you added so the real people can help. After you figure out the water chemistry, we need to work on getting the DUCK out of the pool that was there this morning!
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Lincoln, NE
    17
    Re: 5 day old pool
    Cripes, I can't remember how much! I know, I know, you're eyes are rolling back into your head right now. I believe it was 40 oz?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: 5 day old pool
    Hi!
    Sounds like you have the most important thing already, a test kit. Seems like you're doing fine. You already know to wait to test CYA. Just assume it's at whatever level you calculated and keep FC in the range suggested by Pool Calculator. If it's brand new construction, you'll have to follow the builder's recommendations about pH and TA.
    Aug 2009
    North Central Texas
    1,358
    Re: 5 day old pool
    Welcome to TFP.
    Your friend crek has guided you well. Looks like you are already starting on the right foot. In no time it will all be so easy. Ask, ask, ask. As some members say, the only dumb question is the one not asked. People here on the forum have the patience of Saints.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    22,544
    Re: 5 day old pool
    I know that low CH doesn't matter in a vinyl pool but we like to see it anyway.
    If you added 40 oz of stabilizer you should wind up with about 25 ppm CYA. That's a good place to start but you're probably going to want to up it a little more.
    Your pool is closer to 13,000 gallons but that's not an issue. Just mentioned it so that when you're overshooting your addtions you'll know why.
    I'd keep the FC where you have and see if the CC will go away but .5 isn't a problem.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: 5 day old pool
    How does the water look now?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: 5 day old pool
    Welcome to the forum
    crek, nice job!
    Your TA is a little high, but if you do not have problems with pH rising, leave it alone.
    If you find that you are having to add MA to lower pH often, you can take steps to lower TA.
    You could add your location in your profile and then maybe post some pics.
    What's this about a duck in the pool?
    You're done SLAMing when:
    Re: 5 day old pool
    Won't speak for mokenews, but the duck was real, so if anyone thinks she should bump her FC for a bit, please advise.
    11,969
    Re: 5 day old pool
    Nah, but have her put some rubber snakes out - someone posted on here that keeps them away...
    Lincoln, NE
    17
    Re: 5 day old pool
    ok, put my location in. The duck was real and even though I live in good old farm land, I've NEVER woken up to a sight of a duck swooping down into my backyard! I praying he doesn't tell his friends. So, never again will I leave the solar cover off at night. I snapped a pic w/ my cell phone so we'll see if I can't figure out how to post. My PH has stayed the same at 7.5 since Saturday.
    Lincoln, NE
    17
    Re: 5 day old pool
    Boy, I am a numbnut. Location does not go in sig. line, but off to the left. Please forgive me all. I'll correct it.
    30,414
    Re: 5 day old pool
    How does your water look?
    Lincoln, NE
    17
    Re: 5 day old pool
    water looks good, however I have a very dark blue liner, so not sure if I am seeing the "true" color.
    30,414
    Re: 5 day old pool
    If the water looks nice and you have some chlorine in the pool, it's time to start swimming (with or without the duck...your choice ).
    Why don't you test for CYA on Wednesday-Thursday and check your chlorine daily.
    2-5ppm chlorine should keep the pool sparkling.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: 5 day old pool
    Quote Originally Posted by mokenews
    No problem. We have a place to add it in the profile, but many members add it to their sig.
    Either way is fine. It is nice to know the location (weather) when responding to posts.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: 5 day old pool
    Who cares about just ducks, I used to occasionally swim at a racket club in south Louisiana that had a real problem keeping alligators and ducks out of the pool, talk about a mess. The club was located on very picturesque swamp land, when alligators were present the ducks would try to escape to the pool, and the alligators would follow.
