Thread: Skimmers draw water unevenly?
    Apr 2010
    Syracuse, NY
    103
    I have 2 skimmers, plumbed together, and the one closest to the pump draws water a lot faster. If I close the flow control slide plate a little on the skimmer that is drawing more water, will the other skimmer increase it's draw? In other words will they draw more evenly? Thanks.
    20,000 gal., Jacuzzi 250L Laser Sand Filter, inground w/vinyl liner, 1hp pump motor, TF-100 Test Kit.
    Re: Skimmers draw water unevenly?
    Yes, if you can find the correct setting for the slide plate you can balance out the skimmers.
    Apr 2010
    Syracuse, NY
    103
    OK. Thanks Jason.
