Thread: Is it posible to buy a taylor cya test,buy it self?
    I have a taylor k 1004 witch doesn't test for cya,would i be able to buy just what i need to test for cya and if so what would the product codes be.
    Thanks
    42,000 liters inground pool
    swg aqua rite
    Hayward super filter sand
    Vinyl lining
    Haward 1.5 hp pump
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Is it posible to buy a taylor cya test,buy it self?
    http://tftestkits.net/Cyanuric-Acid-Test-p48.html
    edit...
    I also recommend getting the CYA Standard Solution.
    The CYA test is a little tricky to determine end point (when the black dot disappears). With the standard solution you can see exactly what it should look like.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Quote Originally Posted by svenpup
    edit...
    Thanks
    swg aqua rite
    Vinyl lining
    Haward 1.5 hp pump
