Thread: Return air bubbles
    Jun 2010
    Northern Vermont
    31
    Return air bubbles
    Hi everyone,
    I have a 25,000 gal IG vinyl pool. I began the opening process late last week, and all seems to be going fine except that yesterday we noticed consistent light bubbles coming from the two returns. We have a Hayward 1/2 HP motor on a Rainbow M series 8 cartridge filtration system. Everything in the pool shed looks dry -- no leaks that I can see.
    In addition to the two returns we also have a Polaris hook up with a booster pump. Water regularly flows (lightly) through the Polaris return, and we sometimes get bubbles there too. Last year we did find that there was a leak on the Polaris return line. Our local pool guy cut it out and spliced it.
    So, any thoughts on where the air is coming in and what I can do to trouble shoot the issue?
    Thanks!
    25,000 Gallon, IG, vinyl, Pentair Whisperflo WFDS-24 (2-speed), 8 Rainbow M Series cartridge filters, unheated
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Return air bubbles
    You probably have a leak before the pump. Check your pump strainer lid and drain plug for good, well lubricated O-rings, and make sure they are tight. Next, check any unions or union-type valves on the suction lines for tightness.
    Jun 2010
    Northern Vermont
    31
    Quote Originally Posted by JohnT
    I can lube the O rings with silicone, and check the pump strainer lid. As for the drain plug ... I'm not sure what that is. I know on the front of the cartridge system there is a pipe that looks like it is sealed with a putty & plug of some sort. There is also a faucet on the opposite end of that pipe that I've never touched. Is this where the plug is?
    SW Indiana
    9,199
    Quote Originally Posted by Backyardchemist
    On the bottom of your pump strainer basket, there is a small threaded plug to drain the basket for winterization.
