Thread: What is the best water testing kit?
    What is the best water testing kit? I have been using test strips, but the test strip results don't match the results I get from the water testing results from the pool center/store. Are there home test kits that give actual numbers rather than just colors? Maybe it's my age and I am going a little color blind.
    Thanks for your help.
    Older poured concrete 15K pool; epoxy paint; Hayward DE; 1.5 pump.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,991
    Re: What is the best water testing kit?
    The TF-100, from TFTestKits.net, is a better test kit than most pool stores use. In the TF-100, only the PH test requires color matching.
    Thanks for the information and quick response.
