Thread: alkalinity test ?
    alkalinity test ?
    I did a alkalinity test and it took 8 drops be make it change from green to red except it wasn't really red it was almost inbetween the two colors
    like pink .
    It took 1 extra drop to make the color rich so do i count it as 9 drop witch equals 90 alkalinity.
    Also does rain water have alkalinity in it?Or any other of these testable matters.
    Thanks
    42,000 liters inground pool
    swg aqua rite
    Hayward super filter sand
    Vinyl lining
    Haward 1.5 hp pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: alkalinity test ?
    Slightly redder than Barbie Pink is the color. You got it.
    Rainwater should have nothing in it, but you can read it's pH.
    You want to add drops till the color starts changing to anything kind of red/yellow/clear, then continue adding drops as long as the color continues changing. The final drop, which doesn't change the color any further doesn't count.
    Rain water normally has a very low TA, often around 10.
    Thanks
    These taylor test kits are amazing.I already want to order the k2006 after using the taylor k1004 for the first week.They are very simple to use and they really give you confidence that you have the right results.
    swg aqua rite
    Vinyl lining
    Haward 1.5 hp pump
