Thread: 6% or 12% bleach with the LQ?
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    Which do people find works best with the LQ? I am currently using 12% chlorine from the pool store daily for my chlorinating needs, so I'm wondering when my LQ shows up if I can continue to use the 12%, or does 6% help prevent some of the white stuff (I'll be doing the 3/8" mod)?
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    Mantua, NJ
    80
    Re: 6% or 12% bleach with the LQ?
    I use 12%, without problems, in my LQ.
    Joe
    21k IG vinyl, 300 lb. sand filter, 1hp pump, Polaris 280 cleaner, 3/4hp booster pump, 240sq ft Fafco solar, Liquidator
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    I use both, buying by price, and never have the white stuff.
    May 2009
    So Cal
    44
    I use both, and only had problems w/ tws on initial start-up, after that no problem. I will say that the clorine that I was buying from HD had allot of other stuff besides clorine that settles on the bottom, since I have been purchasing the 12% from the pool store I have very little other stuff ending up on the bottom.
    TRW
    15 X 28, 12,000 Gallon, (IG) Freeform Dark Gray Plaster/Gunite with attached 10 X 7 Spa raised 18", 7 Jet with Spillover and Art Rock Waterfall/Grotto, Pentair Intelliflo VS-3050 for Pool, 2 HP Whisperflo for Waterfall/Grotto, Pentair Clean & Clear Cartridge 320, Pentair 400K BTU Matstertemp, Pentair EasyTouch 4P, Pentair Suction Side PoolShark Cleaner, Stenner pump, autofill system, Plumbed for future Solar, TF-Testkit.
    22,542
    I use mostly 6% wally world brand and have had no problems.
