Results 1 to 8 of 8
Thread: hayward parts broken
    Jan 2010
    Murrieta, CA
    9
    hello tfp
    i have a hayward de4800 which i plan on cleaning this week. so upon further inspection i realized the filter head missing a Pressure Gauge, Relief Valve/ Gauge Adapter Assembly and o-ring, these parts are required i'm i certain right to relieve pressure or is there any work arounds without the parts. And yes i did buy some replacement parts. oh and how do i work a Slide Valve Assembly to rinse and backwash. and for the record, none of this was our fault but a foreclosure house.
    May 2008
    Long Island, NY
    151
    Re: hayward parts broken
    I broke mine this year. It is a standard replacement part. Cost about $20. Part number DEX2400S. It is not a pressure relief valve. You use it air vent air from the filter.
    Try unscrewing the black part that is on the filter. The part should screw directly into the filter housing.
    Pool Details: 25,440 Gal IG Vinyl 21x40 Mountain Pond (Graphex)
    Filter: Hayward Micro-Clear DE (48 Sq Ft)
    Pump: Hayward SP2603VSP VS Super Pump
    SWG: Circupool Si45
    Cleaner: Pentair Kreepy Krauly Prowler 820
    You can look up your filter here, there are part numbers etc. you might find usefull.
    http://www.haywardnet.com/abovegroun...fm#FiltersD_E_
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    Jan 2010
    Murrieta, CA
    9
    acamato can i still disassemble so i can follow through with cleaning my filter as is?
    Jan 2010
    Murrieta, CA
    9
    do i need to unscrew that part since parts are missing or simply skip it while the pump is off to disassemble
    Jan 2010
    Murrieta, CA
    9
    anyone?
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Sorry to have ignored your issue
    The part you're looking for is a DE 2400 ? (my parts manual says DEX360AR), but I know there is another part # for it.
    Luv& Luk
    -Ted
    Jan 2010
    Murrieta, CA
    9
    just received my spare part and started bleeding the air. what i learned from the previous owner as to what the misc was broken is cause he screwed in the part to were it broke like just now
