Thread: Need Pump Advice
    Apr 2008
    S.E. Michigan
    2
    Need Pump Advice
    Well, the screeching of the pump has finally led to the pumps demise. Running very hot and tripping the thermal overload. I had hoped that I could just replace the bearings but the thing is so corroded that I have given up. What do the folks in the know recommend for a new pump? Out going motor is a 1 hp 1.25SF A.O. Smith motor under the guise of Sta-Rite, hooked to a Dura-Glas II pump. Pool is 35,000 gallon, 20x40, 3ft shallow, 9 ft deep end. I just starting running 240sq ft of solar this season. The house was abandoned when we moved in so we have no history of the equipment. Pump definitley looks like it has more then a few miles on it. Any advise would be greatly appreciated. Thanks
    Kevin
    Kply
    35,000 In-Ground Concrete/Plaster with spillover spa.
    30,402
    Re: Need Pump Advice
    Hi, Kevin
    Welcome to the forum. Can you see what the flow rate on the filter is? That'll help choose the pump.
    Apr 2008
    S.E. Michigan
    2
    It is sand filter rated at 52gpm. Thanks.
    Kevin
    Kply
