Results 1 to 10 of 10
Thread: Using test kit
    Barbara C's Avatar
    Jun 2010
    Southern Indiana
    124
    Using test kit
    New to using a test kit. I don't have my good kit yet but I'm practicing with a 3-way OTO kit from walmart. This may sound silly but what's the best way to fill the cells? I seem to get too much or not enough water in them. Does it have to be dead on??
    Barabara
    24' AG Vinyl
    13,500 gallons
    1hp Hayward pump
    Sand filter
    Jug dumper apprentice
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Re: Using test kit
    It should be as close to dead on as you can get it. The bottom of the meniscus, that rounded part, should be level with the fill indicator line.
    I fill the cell by pouring water into it from my collection bottle. Then I sort of snick my wrist to spill some of the water back out. With a little practice you can do this one or two drops at a time, depending on how hard you snick.
    Many people use a squeeze bottle to fill their test containers. That allows you some pretty decent control of volume.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Re: Using test kit
    The OTO chlorine test and the associated PH test aren't especially sensitive to the exact amount of water in the chamber because they are color comparison tests. Titrations, which most of the other tests use, are much more sensitive to amount of water being exactly right (or more importantly, the same each time you do the test).
    Barbara C's Avatar
    Jun 2010
    Southern Indiana
    124
    Re: Using test kit
    Thanks AnnaK! I've been relying on the pool store way too long!!! I will practice snicking my wrist. If I can't get that down I guess I can empty the Visene bottle and use that. Once I empty one of the reagent bottles that should work well too. I'm assuming the fill indicator line is the one that's in the middle of the top square???
    Jason, thank you also. I will be sure to be consistent with the TF100 when it arrives.
    24' AG Vinyl
    13,500 gallons
    1hp Hayward pump
    Sand filter
    22,553
    Re: Using test kit
    I normally use a syringe to add water to the OTO/pH block and to the test vials. That allows me to get the amount exactly. When I take the block to the pool I fill the block to the top and thump the pH block while I hold the CL side. I can get it real close that way.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Using test kit
    I collect my sample into a plastic measuring cup with a spout. Then it's simple to pour it into the vials. If I overfill, a flip of the wrist will slop some out. It doesn't take long to get good. If too much goes out, it's easy to dribble a little more in with the pour spout.
    Re: Using test kit
    I use the collection bottles that my local pool store gave me. It has a squeeze top and I can easily get as little as a drop or two as needed.
    Jan 2009
    Cupertino, CA
    1,966
    Re: Using test kit
    Any soft-side water bottle with a pop-top works well. Grocery-store water usually comes in pretty flimsy bottles that don't last long; two local bike shops have sturdier bottles with their logo on it for cheap.
    --paulr
    BBB "Intermediate Swimmer"
    Barbara C's Avatar
    Jun 2010
    Southern Indiana
    124
    Re: Using test kit
    All wonderful ideas. I'll see what works best for us. We hadn't thought about a pop-top type of water bottle. I probably have a few of those around. So far the measuring cup with a spout has been working well. I'm getting pretty good at flicking my wrist.
    Thank you so much.
    24' AG Vinyl
    13,500 gallons
    1hp Hayward pump
    Sand filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Using test kit
    I like using a glass measuring cup, less worry than something in a plastic container leaching into the water, but of course that means glass breakage risks.
