Thread: Navigator hose keeps twisitng...
    Both feet are moving, plenty of suction. It does seems to go left a lot more than right, but it does go right still...
    Any ideas?
    South Florida. 20,000 gallons; 16x35 rectangular gunite; Pentair Intelliflo VF Variable Speed Pump; Hayward cartridge; Aqua Rite SWG. Dolphin Oasis Z5 Robotic Pool Cleaner; Kopec 540sc Electric Heat pump pool heater; Pool built in Spring 2004.
    Mar 2007
    Murrieta, CA
    215
    Re: Navigator hose keeps twisitng...
    Bump.
    I'm having the same problem. Only wants to turn left, and then only about every 3-5 minutes. Constantly getting stuck in corners and twisting the hose. I've taken it apart several times, and don't see anything broken.
    ~13500 gallon gunite pool, Pentair Intelliflo 4x160, Pentair 520 SF cartridge filter, Pentair MasterTemp 400 NG heater
    Pentair Easytouch with IC40 SWCG, Hayward Navigator on dedicated suction line
    Guest
    Have you replaced your flaps??? Also, look at the two bearings in side and make sure they are not worn. Probably time to rebuild your little guy!
