Thread: Base of Multiport Leaking Water
    Russellville, Arkansas
    4
    For the first month of the season I had no problems with my Eco Kleer multiport filter. Then, last weekend, it started leaking a significant amount of water from the base of the multiport and the water tank, enough to visibly drop the water level before it was noticed. The pump and filter are still pushing enough water to recirculate. I tightened the connection (no help), removed the multiport and reset the o-ring and retightened. No help. Could this be an o-ring failure? What would cause water from the water tank to start leaking significantly overnight? Thanks!
    AG Miramar 27'x54" (Not yet installed).
    22,553
    Re: Base of Multiport Leaking Water
    It could be a crack on the neck of the vessel or the multiport. A close inspection should tell you where it's leaking from. It could also just be that the o-ring is old and needs replacing.
    Did you lube the o-ring when you removed and replaced it?
    4
    I'll check for a crack. I haven't replaced the o-ring. The only time I've exposed it since installed the pool last July was to replace sand this spring. I did not lubricate when I put it back in place. The o-ring does appear to not be completely circular. I am surprised at how it is just not leaking but putting water out under pressure from the base of the multiport. Barring no cracks, my first option should be to replace the o-ring? Thanks!
    22,553
    Your first option should be to open it up and lube the o-ring and put it back together correctly.
