Results 1 to 9 of 9
Thread: Water Chemistry - Whaddya Think?
    Greetings,
    My pool water is crystal clear. I have the following:
    FC 3-5
    pH 7.2
    TA 230
    CH 150
    CYA 50
    Should I be concerned about the high TA and/or low CH?
    Thanks!
    Mark
    Mark Stinson
    Woodland, CA
    IG 12,545g Gunite/Plaster with attached spa, Hayward Northstar 3HP pump, Pentair Clean & Clear Plus 420
    Alas, I have no heater for my spa (yet)! :-(
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Water Chemistry - Whaddya Think?
    You should be concerned about the low CH for the sake of your plaster.
    If you just maintain your pH in the lower end of the range, TA will drop over time.
    Butterfly's Avatar
    South Carolina
    10,045
    Your FC is 3-5?
    With CYA of 50, your maintenance range is 4 to 8.
    How are you testing?
    You're done SLAMing when:
    Thanks for the super fast replies!
    I should have noted that I have been lowering the pH. It was 7.8. M
    I haven't added any liquid chlorine in several days as I have been trying to bring down the pH and didn't want to add both chemicals on the same day. I tested with my new TF-100 kit. I used the FAS-DPD test for FC.
    Mark Stinson
    Woodland, CA
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by ReluctantPoolBoy
    There is NO problem adding both chems on the same day, just make sure to have about 30 minutes pump time in between.
    I suggest you add chlorine each evening up to your target level.
    That is what most of us "Jug Dumpers" do (thanks for that svenpup )
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Greetings,
    FC 3-5
    pH 7.2
    TA 230
    CH 150
    CYA 50
    Thanks!
    Mark
    I find the CH number hard to believe, since you're in California. My tap water runs almost 300 CH! You didn't transpose the TA and CH numbers by chance?
    Quote Originally Posted by Richard320
    I tested it twice for the same reason!
    Mark Stinson
    Woodland, CA
    Greetings!
    I have been maintaining my target FC and a slightly lower than target pH. Just as John T. said, my TA is slowly dropping. It's now 180. Unfortunately, my CH is also dropping. It's now down to 100. I'm concerned about the low CH number. Is it time to add some calcium chloride?
    TEST 4/11 6/27
    FC 7 7
    TC 7 7
    pH 7.2 7.2
    TA 230 180
    CH 150 100
    CYA 50 60
    Mark Stinson
    Woodland, CA
    CH doesn't just drop like that, so I suspect there is a testing error of some kind.
    For a plaster pool, you should keep CH between 250 and 350, so you definitely need some calcium even if your CH level is still 150.
