Thread: Fitting removal
    Fitting removal
    Need to remove the fitting where water returns to the pool. I have removed the outer ring and eyeball, no problem.
    I need to remove the fitting that all of that attaches to . The directions for my pool cleaner says to remove these so that I can hook it up.
    It is a Polaris Turbo turtle. There is about an 1/2 inch of threads showing , I have tried channel locks . The guy who installed the pool last year recommended one of those grippers ( like for mason jars ) so I put the channel locks on it and tried. No luck.
    He said its not glued in , but I am beginning to wonder. Any ideas ????
    Above ground 33 ft round 52 in. high
    Approx. 25000 gallons
    Hayward Dreamline Sand filter holds 250lbs sand
    Hayward CL-200 chlorinator
    Hayward 1.5 hp 67 GPM pump
    22,548
    Re: Fitting removal
    They make a tool to remove the eyeball holder. Check with your local pool store and see if they have one in stock.
    Re: Fitting removal
    I asked the installer that question last year and called the pool store owner also , even checked with the local pool store last week and they all say " oh you just have to grip it and it will unscrew "
    Well show me how ???
    I will try searching on the web .
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Fitting removal
    I recently removed my eyeball fitting for the first time in 5 years. It was tight! Also I had a ring that screwed tight to the wall of the pool. Once I loosened it the fitting loosened as well and I was able to remove both pieces from the return. The fitting went through the ring and screwed into the wall of the pool. If it just doesn't budge you may be able to find and adapter that will connect the Polaris to the return fitting.
    Love TFP? Become a
    TFP Supporter!
