Results 1 to 11 of 11
Thread: Pool Stained After Adding Borax
    I used borax last year and the pool has developed some nasty stains, I never had any staining before
    It almost looks like rust brown/yellow staining
    I read about the ascorbic acid treatment
    Will this work here?
    I also found citric acid in quantity which I used to use on stains on dishwashers when I used to service them
    Which is more effective, I see citric acid is much less expensive?
    I have a 16x32 vinyl pool approx 22k gallons running a de filter
    it is a salt pool now and I am using a intellichlor chlorinator, the stains were before I added the pool salt
    I see I have to get the chlorine level as low as possible
    what dosage of ascorbic or citric acid should I use
    thanks for the help...
    16x32 Vinyl Inground
    Haywad EC-65 DE filter
    Intelliflo VF Pump
    Intellichlor ic-40 chlorine generator
    Solar Panels
    Re: Pool Stained After Adding Borax
    You can use citric acid, but you need twice as much as you would of ascorbic acid, even so it is still less expensive.
    The first thing to do is to check that the stains respond to citric/ascorbic acid. The simplest way to do that is to get a vitamin C tablet and hold it against a stained area for 30 seconds. If the stain clears up in that area, you should do an ascorbic/citric acid treatment.
    There is a good write up on how to do the treatment here.
    thanks for the response I have some powder vitamin c i will take a look now
    any idea on dosage for a 16x32 pool?
    Intelliflo VF Pump
    Solar Panels
    i tried the vitamin c on several spots they all came out
    Intelliflo VF Pump
    Solar Panels
    I'd buy 1.5 lbs of ascorbic acid or 3 lbs of citric acid, but try half that much to start with.
    how / why does Borax cause stains?
    TFP SUPPORTER through TFTestKits.com - My Pool: South Florida, 11K gallons, In ground, concrete / Diamond Brite, Free Form with attached spa (no heater- go figure) Built around 1998, original surface, Jacuzzi Magnum Force 1.5HP pump, Jacuzzi Cartridge Filter, Rainbow 320 Tablet Feeder, Hayward Navigator Pro, Taylor K-2006 w/ TFTestKits replacemeng Reagents.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Borax doesn't cause stains. High PH and metals present in the water can cause the metals to drop out of suspension and deposit on pool surfaces. Borax raises PH so too much can cause it, or localized application, etc.
    Quote Originally Posted by frustratedpoolmom
    its probably my fault I didnt mix it just hrew it in but my ph was VERY low and I ended up using quite a bit
    first time in 13 years i made that mistake, never had a liner discoloration before
    Intelliflo VF Pump
    Solar Panels
    i found ascorbic acid crystals at trader joes for 9.99 a lb
    i used part of 1 bottle the other day to clean the stairs, maybe 3/4 lb then it started raining
    i looked out this morning and it was almost clean ( i let it run 2 days )
    I just added more, i imagine the liner will be sparkling clean
    my water is crystal clear, i have the intelliflo vf pump and at its lowest setting it uses 100w
    runs slow but i leave it on 24/7 since i can afford 100w 24/7 and the water stays beautiful and the filter rarely gets too much pressure
    im glad i found this forum
    Intelliflo VF Pump
    Solar Panels
    added the rest of the ascorbic and the pool is gorgeous again
    i did notice however i had to add another 80 lbs of pool salt to get the choline generator working again
    Im not sure its because the weather has cooled or the ascorbic reacts with the salt
    Intelliflo VF Pump
    Solar Panels
    There often needs to be a little more salt when the water is colder. AA and salt don't interact.
