Results 1 to 11 of 11
Thread: OTO or DPD?
    jeffcessna's Avatar
    May 2009
    Tennessee
    60
    OTO or DPD?
    I cant seem to find a definite answer and was wondering if you only have either an OTO or DPD test kit (like I do) which one would be better to use?
    Intex 20' metal Ultra Frame round 9400 gal, standard 1500 gal/hr Intex cartridge, K-2005 Test Kit, AG, vinyl -- my practice pool until we can get a real AG or IG....:)
    30,131
    Re: OTO or DPD?
    For the kind of testing needed to manage your pool really well, I would say neither. Most people find the FAS/DPD chlorine test an invaluable part of their testing and wouldn't use anything else.
    OTO tests for the presence of chlorine but it's accuracy is good for little else. I have never used DPD.
    Re: OTO or DPD?
    It depends on what you are doing. They both have advantages and disadvantages, just in different places. DPD can distinguish between FC and CC, which OTO can't. On the other hand DPD will show zero chlorine when the FC level is actually very high. DPD is noticeably better at distinguishing between FC levels around 3 to 5.
    The FAS-DPD test is much better than either of those in nearly every way.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: OTO or DPD?
    I find the OTO test kit included in the TF100 kit to be handy for quick ball park chlorine level checks, but it is a BIG ballpark and it is also handy as a double check against the FAS-DPD, I have used tests that were DPD in the past, they are somewhere in the middle, a little easier than doing the FAS-DPD, but have the color matching problems of OTO.
    So
    OTO - quick easy 1 step ballpark total chlorine number
    DPD - mid level test but tells you both FC and CC (at least in a ballpark)
    FAS-DPD little more work than DPD, but tells you to the .5 PPM level for both FC and CC and best of all NO COLOR MATCHING just pink or clear
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Re: OTO or DPD?
    ditto what isaac said.
    since my target on the high end is 9 and my minimum is 4 or 5, there's a biiiiigggg range there on the OTO.
    I use FAS DPD every day. Sometimes twice.
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    jeffcessna's Avatar
    May 2009
    Tennessee
    60
    Re: OTO or DPD?
    I went to my local pool store (Pool and Spa Depot) and asked to see if they maybe carried the FAS-DPD test and they didn't have any idea what I was talking about. I tried to explain to them what it was and the man behind the counter told me, "We don't get that technical." I was taken aback and decided that there was no way I was going back in that store again....ugh. I am going to have to eventually just get the FAS-DPD test kit so I can test accordingly. For the time being I will continue to use the OTO for daily tests and the DPD maybe every other day to TRY to verify.
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Re: OTO or DPD?
    Jeff,
    Eventually is NOW. Just order that test alone and it will change everything.
    jeffcessna's Avatar
    May 2009
    Tennessee
    60
    Re: OTO or DPD?
    I was just looking at the Taylor website and I can just order the R-0870 powder and the R-0871 drops for the FAS-DPD test kit instead of ordering the entire kit.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: OTO or DPD?
    You would also need R-003 for the combined chlorine part of the test, a graduated cylinder to get the correct amount of water and the little scoop for the powder. To me is seems easier to order the K-1515 kit as you get a box to keep it in, etc. Note if you use non-chlorine shock like HTH Shock n Swim you want to get K-1518
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: OTO or DPD?
    You can either get the Taylor K-1515 FAS-DPD chlorine test kit here or you can get the FAS-DPD chlorine test kit from TFTestkits here with the latter kit having 2.67 times the volume of reagents so is less expensive per test.
    jeffcessna's Avatar
    May 2009
    Tennessee
    60
    Re: OTO or DPD?
    I don't use shock at all. Just the BBB method Is there any preference as to which test kit to get for just the FAS-DPD test??
