Results 1 to 7 of 7
Thread: A large drop in chlorine, but CC is 0
    tedinelkgrove's Avatar
    Jul 2009
    Elk Grove, CA
    98
    It seems like I am losing a lot of chlorine in short amount of time. I tested added chlorine Thursday evening ~5pm and level was ~10.5ppm. This morning I tested @ ~11am and the FC was 2.5. A loss of 8ppm in a full day of sun and 2 nights. My pool is not leaking; turned automated filler off for a few days before this and level stayed normal after 2 relatively warm-sunny days. I tested CC and color remainded clear after adding the R-003 reagent.
    Any thoughts. Could my volume be off? But then again, is 1-2k gallons going to break the bank here?
    ~15000 gallon inground, plaster pool
    Jandy CL460 Cartridge Filter Tank, Jandy Stealth SHPF 1.5hp pump, Pentair Legend II cleaner
    Leslie's DPD Complete Test Kit, TF Tests FAS-DPD Chlorine Test Kit
    Heliocol solar pool heating (HC-40 x6)
    30,426
    Re: A large drop in chlorine, but CC is 0
    What is your CYA level?
    Jul 2009
    Elk Grove, CA
    98
    Sorry:
    CYA=40
    TA=50 (needed low to combat pH drift)
    CH=280
    pH=7.8
    Borates=50
    30,426
    At that CYA level, I would expect a loss a little less than that.
    How much swimmer load did you have during that period?
    Do the overnight FC loss test found in pool school to confirm you don't have organics in the pool.
    If you pass that test, you might bump your CYA up to around 50 to see if that slows your loss.
    Jul 2009
    Elk Grove, CA
    98
    I lost 1.0 ppm over night. Took first reading at ~835pm when sun set; just took second reading at ~645am.
    You might be fine or you might have some hidden algae. I suggest checking for hidden algae in obscure places that don't get good circulation. Some possible places to look include underneath or inside the ladder, inside light niches, in the auto fill chamber (if you have one), etc.
    Jul 2009
    Elk Grove, CA
    98
    I rechecked CYA, being it has been a month+ since last time. It was below 30ppm, so I added ~1lb of stanilizer. We'll see in a few days if it helps.
