Results 1 to 8 of 8
Thread: Question about Borates
    Jul 2009
    Long Island, NY
    267
    We are about to add borates using boric acid. We have reduced TA to 70 using the muriatic acid/aeration method. Presently, the PH is in the 7.3 - 7.4 range. Can I add the boric acid now or do I have to wait for the PH to get up to the 7.5 - 7.6 range? My feeling is that it will eventually rise on its own.
    Second question: I have read the "So you want to add borates..." thread several times. It mentions using 1/2 the about of borax & muriatic acid and then waiting and testing. Since I am using boric acid, can I use the total amount all at once?
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Question about Borates
    When adding chems that don't go away, it is best to add 1/2 first and retest to make sure you don't overdose and have to drain water, thus wasting chems, time, and money!
    Love TFP? Become a
    TFP Supporter!
    With boric acid, I would go ahead and add it all at once.
    The borate test strips aren't precise enough to give you useful feedback about how closely you calculated the amount, and if the amount is off, it really doesn't matter anyway. The borate level just needs to be approximately correct.
    You also don't have the borax and muriatic acid issue of double checking that you got the relative amounts of the two correct.
    Jul 2009
    Long Island, NY
    267
    Thanks for the replies. What about the PH question? Is the 7.3 - 7.4 range okay to add the boric acid?
    Yes, the PH is fine.
    Jul 2009
    Long Island, NY
    267
    I just added the boric acid and now have approximately 50 PPM! The water looks great. We re-tested the PH and got a 7.2 reading. Is it safe to swim at this level? I would rather not adjust it with baking soda since it will naturally rise on its own.
    PH at 7.2 or higher is safe to swim.
    Jul 2009
    Long Island, NY
    267
    Quick update... Have been in the pool all afternoon. The water is great with the borates! The vinyl liner feels squeaky clean. I am gald that we did it.
