Results 1 to 10 of 10
Thread: FROG System alternative??
    Hi there!
    We just moved to a new house and acquired a 27 ft above ground pool.
    I have been looking around here and also heard from a friend that most people are not happy using the FROG system, which is what the previous owner had used.
    We are trying to look for an alternative.
    Can we eliminate using the Frog system? If so, how?
    What are the other options? I have seen some stuff about BBB, but we don't really mind doing the chlorine thing, so is there another system to use instead of BBB and the FROG?
    THANK YOU IN ADVANCE!
    Colleen
    27' Round Johnny Weissmuller Legend Above Ground Pool
    Capacity: 17,200 Gallons
    Water Depth: 44"
    Filter: Waterway Clearwater II, 150 Sq. Ft.
    Filter Type: Cartridge
    Pump: Waterway HI-FLO 48 Frame, 1.5HP, 2 Speed
    I'm chucking the pucks...heck, we never even started them, we ditched the FROG and went straight to BBB!
    22,548
    Re: FROG System alternative??
    You can just leave the Frog empty. You could install a SWCG if you didn't want to add chlorine all the time. You could also use a liquidator or injection pump to automatically add chlorine for you.
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Welcome to TFP Glitter Girl!!!
    Disclaimer: Glitter Girl and I sometimes get LOST together and we go waaaay back...!!!
    Glad you are here!!!
    Congrats on the new home, pool, etc...
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    Feb 2010
    Houston, TX
    271
    Quote Originally Posted by poolgirl22
    So THIS is the one you were talking about the other day...oh no, not another one!
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Hi Glitter Girl, welcome to tfp. Imho I would go with the swcg like Bama Rambler said. As long as you dont mind your water tasting a little bit salty it is by fare the best way to go. The Pool store we purchased our pool from tried telling us how great this aqua smarte system was, which is the same thing as a pool frog and I checked into it and found out from all the wonderful people here at tfp pools that it was a joke. Just another way for the pool stores to suck the money out of your pocket. We removed it and sold the whole system on ebay. I put in a intex swcg for like 200 or so including the salt. We love it and I couldn't be happier. The intex swcg I purchased I got off of amazon for 140.00 with shipping and I purchased morten pool salt from walmart. Make sure if you do get a intex swcg you get the 2009 model and not the 2010. The 2010 has copper plates which you don't want.
    Daniel
    24' 52" Agp 13500 gallons, PoolSchool, BBB, eco/kleer pump/filter 2.0 hp 70 gpm
    two 2'20' solar panels, 8110 intex swg
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    No cheddar, this one listened.
    LOL! Hi there and thanks!
    And THANK YOU for referring me to this site! I can tell it is going to help tons!
    Colleen
    Water Depth: 44"
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    I told you this place was great!
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    The Pool Frog, Nature 2, and other such mineral systems do little more than add metals to the water. Although metals do have some algaestatic properties, they can cause staining to pool surfaces and are largely not needed. On top of that, the replacement cartridges are wildly expensive. You can simply remove the cartridge from the system, close it back up, and leave it be.
    These types of systems are not required to have a beautiful pool. By maintaining an appropriate chlorine level, you will never have algae and the pool will always be sparkly. Many of us use bleach to chlorinate, but as has been suggested, the SWCG systems are awesome too.
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    I plan to put a SWG on a new pool install if I ever do one. I just can't justify the expense right now..so being a jug dumper works just fine for us. It seems like a lot to lug those bleach jugs but when I look at what I've spent just in bleach this year, it isn't even close to the rest of the junk I purchased previous years.
