Thread: Ooops, that just happened.
    chris4150's Avatar
    Apr 2009
    Cypress, TX (suburb of Houston)
    Hello all,
    After a week of daily bather load, temperatures above 90 each day, and two days of rain, I finally got around to checking my pool chemicals and was horrified and shocked to see that my FC dropped to 0
    I immediately checked my PH to balance it and then confered with the pool calculator to raise my FC to 6 based on my CYA of 50.
    After brushing the pool down subsequent to the addition of bleach, my water is a bit cloudy. I would imagine that the cloudiness is due to the bleach attacking any unforseen algae etc.
    My question is should I shock the pool or just maintane my FC at the desired level of 6 ppm or raise it to 8 ppm and maintane it at that level?
    Let me know what you guys think.
    13,500 gallon free form Pebble Tec pool- 2 skimmers
    Pentair Intelli-Flow filter pump, Pentair Intelli-Super Flo booster pump, waterfall pump, Del Ozone Eclipse 1 generator, Pentair Clean & Clear Plus Cartridge filtration, Nature 2 XG Clear Vision, In-line Chlorinator, Polaris 280, Raypack heater, and Color Logic LED lights.
    Proud user of BBB, pool school, pool calculator, TF-100, and the advice of the friendly people here!
    Re: Ooops, that just happened.
    Definitely add some more chlorine. Since the water is already cloudy, I would aim for shock level tonight. Hopefully, you will still have a plausible FC level tomorrow and won't need to do a full round of shocking the pool.
    The sooner after FC goes to zero that you can raise the FC level up, the better your chance of recovering from it quickly.
