Thread: Noob - New Test Kit - First Test Results - Please Advise
    11K gallon, In Ground, Concrete
    FC = 9.2
    CC = .8
    PH = 7.3 (Base Demand = 2 drops)
    TA = 70
    CH = 230
    CYA = 85
    This is my first test so please go easy on me.
    TFP SUPPORTER through TFTestKits.com - My Pool: South Florida, 11K gallons, In ground, concrete / Diamond Brite, Free Form with attached spa (no heater- go figure) Built around 1998, original surface, Jacuzzi Magnum Force 1.5HP pump, Jacuzzi Cartridge Filter, Rainbow 320 Tablet Feeder, Hayward Navigator Pro, Taylor K-2006 w/ TFTestKits replacemeng Reagents.
    22,553
    Re: Noob - New Test Kit - First Test Results - Please Advise
    I assume by the numbers that it's a K-2006 or Leslie equal. Oops, never mind, I see it in your sig.
    Your numbers don't look too bad.
    Your CYA is too high for a non-SWGC pool. You need to work on getting that down and swap to some chlorinating source that doesn't add CYA.
    The .8 CC bothers me a little. I'd jack the FC up a little and see if it'd go away.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Welcome You are on your way to taking control of your pool.
    First off, I recommend switching to the 10ml (0.5ppm per drop) version of the Chlorine test versus the 25ml (0.2ppm per drop). You really only need that level of accuracy and you will save your reagents.
    The Acid Demand and Base Demand tests aren't necessary if you are going to use Jason's pool calculator. I have the K-2006 also, and I took them right out of the box (to make room for my magnetic stirrer).
    Your CYA is a little high, but manageable. Just make sure you use the target and shock levels based on either Jason's pool calculator or the CYA/Chlorine chart.
    Alternately you could do a partial drain and fill to get the CYA down to ~50.
    If your CC number is correct you could probably stand to shock. Remember that shocking is a process and not a product. Read "How to Shock" in pool school if you haven't already.
    Your pH will probably drift up, so I wouldn't touch that right now. It is better to shock at a low pH anyway.
    Good Luck!
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Thanks for the replies!!! Yeah, I realize my CYA is high. I'm pretty sure it's due to the trichlor tabs I recently started using. I've cut those back so hopefully I'll get that under control in time.
    Here's my next question... I've plugged in the data into the Pool Calculator and here's what it says:
    add 24oz of borax
    add 77oz of baking soda
    But it also says this:
    "Note: pH calculations depend on TA and Borate. Results are approximate and can be off significantly for large pH changes. Changing your pH will also change your TA."
    and this...
    "Note: Adding baking soda will also raise your pH."
    So this leaves me wondering how to resolve my PH and TA. What does the hive recommend?
    THEN... What about CH? Can I just follow the instructions without worry?
    "Add by weight or by volume of calcium chloride
    or add by weight or by volume of calcium chloride dihydrate."
    I believe this is one of those things there's no 'grocery store' substitute for, correct? Which of the 2 products recommended should I get?
    And lastly, with my CYA levels so high, what should be my FC goal? And actually, what should by my TA goals too?
    Thanks in advance!!!
    Your TA and PH are both fine where they are. If, in the future, you do need to change both PH and TA, you change one of them first, then measure the other and change it as needed at that point.
    Calcium chloride can be found as an ice melter in some areas in the winter, but is fairly hard to get a hold of during the summer or in places where there is never any need for melting ice. As a result, you will often end up having to get it from a pool store. They will sell something like "Calcium Increaser" and you then need to look on the packaging to find out if it is calcium chloride or calcium chloride dihydrate.
