Results 1 to 7 of 7
Thread: Is it worth cleaning sand filter after 5 years?
    Hi i have a five year old sand filter witch is working great and my water is sparkling clean.Should i open it up and clean of the dirt on the top or should i just leave it the way it is till i start having problems.
    I never touched it in five years.
    Thanks
    42,000 liters inground pool
    swg aqua rite
    Hayward super filter sand
    Vinyl lining
    Haward 1.5 hp pump
    22,548
    Re: Is it worth cleaning sand filter after 5 years?
    If it's working great I wouldn't fool with it. Just backwash it real good once in a while.
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    242
    I agree. My motto is if it aint broke, dont fix it!
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    What is a really good backwash?How much time?
    Thanks
    swg aqua rite
    Vinyl lining
    Haward 1.5 hp pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,993
    Just don't be surprised when you develop problems afterwards. There are gaskets and seals in the backflush valve that haven't moved in a looooong time. They may crack or tear if you use it.
    Quote Originally Posted by Richard320
    I'm not quite understanding what you meen.Are you saying that i shouln't do a big long backwash?
    swg aqua rite
    Vinyl lining
    Haward 1.5 hp pump
    Richard320's Avatar
    Jan 2010
    18,993
    Quote Originally Posted by bats
    Not at all! If you're going to backwash, make it worthwhile.
    What I'm saying is that gaskets and O-rings get hard and brittle with time, and take a set. Disturbing them may cause them to start leaking. I don't know what style backflush valve you have, but if it's one of those old up-n-down push-pull valves, you may all the sudden see water dribbling out around the shaft. You may see strange things happen with pressure, you may see fine sand spewing out your returns. Or maybe nothing will happen. Just for amusement, go use the search box at the bottom of the page and enter "spider gasket," then read some of the posts. Then you won't be blindsided.
