Results 1 to 8 of 8
Thread: Problem with Pump
    Problem with Pump
    Hi. I am new to the board.
    I have a rectangle inground pool 32'X16' with a DE filter. The pool was closed for 2years. This year we decide to open it ( The pool was not covered). It is very dirty.
    Please let me know if it is normal for a new pump to stop almost every 2 hours). If not, what could be the problem.
    Thanks
    32'X16' Rectangle IG
    2 hp pump
    36 sq ft DE filter
    New York
    30,400
    Re: Problem with Pump
    Welcome to the forum!
    How are you getting it to restart? That may help give us some ideas.
    22,537
    It's definitely not normal. Your pump should run continuously.
    Does it start back on it's own once it's kicked off?
    Is it tripping the breaker or anything?
    Is it on a timer?
    I would add DE powder in the filter, the pump would run for about 45 minutes, the water going back in the pool was slow down until it stops; the we add backwash, add DE powder almost again every two hours
    2 hp pump
    36 sq ft DE filter
    New York
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Is the pump motor stopping or is the flow stopping? It's fairly normal for a DE filter to need cleaning even hourly when the water is very dirty.
    The flow stops
    2 hp pump
    36 sq ft DE filter
    New York
    Feb 2010
    Houston, TX
    271
    That's normal with a DE filter when the water is very dirty. For maintaining a sparkly pool, you probably can't beat DE. But when you have to clean a swamp, it can be a headache.
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,375
    You need to thoroughly clean your DE filter. Turn off the pump, shut off the valves, bleed the air from the filter and take off the top. Hose off the grids or fingers, whichever you have, until all the old DE has been removed. Re-assemble the filter and re-charge with fresh DE. If you need more detailed instructions let us know.
    Please go to the "user control panel" button in the top left corner of this page, just under the TFP logo. Go to edit signature and add the following details: Pool type and finish, pump brand and size, filter brand, size, and type, and any other details such as salt water chlorine generator, chlorinators, water features, ect... This will help us help you and your pool specs will be included with every post.
    Love TFP? Become a
    TFP Supporter!
