Results 1 to 8 of 8
Thread: reduce water flow for solar?
    Mar 2010
    Kansas
    12
    Hi,
    My 1 HP pump is blowing the connections off of my 3-way valve when trying to hook up the solar. Even when I have the solar blocked off, that is the connection that blows. I tried it half open and it still didn't hold. I am using flex hoses (I know not the best) and clamps on the connections. Do I need to reduce the water pressure somehow before it goes to the solar? My filter was about 18 psi before attempting the solar hook-up. I'll go out and take a picture, though I am ashamed of my meager plumbing attempts after seeing all the professionals here! We are about ready to say "forget it" with the solar - it's been plenty hot already and we might not need it until fall at this point.
    Thanks!
    Intex 18' x 48" metal frame
    Hayward 1 HP/ 100 sq ft XStream cartridge filter
    Intex SWG
    2 2x20 solar heaters on separate pump
    still a work in progress...
    22,553
    Re: reduce water flow for solar?
    Try using two clamps on each fitting. Not an ideal situation but might work for you.
    Mar 2010
    Kansas
    12
    OK, from reading on here, I have figured out that I need to switch my connections so that it goes in the solar at the bottom and out at the top. Other than that, is my pump too big?
    Intex SWG
    That style of hose connection can be finicky to get right. Your pump will be putting a little more stress on the hose clamps then they usually get, so a slightly imperfect connection will fail. Once you can get everything connected correctly, everything should be fine.
    Nov 2009
    Indialantic, FL
    323
    Your plumbing confuses me. It appears that a black flex line comes out of the filter to a 3-way valve. I presume the black flex line coming out of the 3-way goes to the Pool? The white flex coming out the other side of the 3-way then seems to go both (through a "T") to the solar panel and to what I think is the Intex SWG. Where does the output of the solar panel and SWG go?
    In a traditional solar install the flow goes: pump - filter - solar - SWG - pool. If the solar or SWG can't handle the flow there is a bypass loop employed.
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    The black hose from the filter is the water supply. Black from the 3 way valve feeds the solar panels. White is the return to the pool, which goes through an Intex SWG on the way to the pool. Because there isn't a check valve, the solar panels are pressurized any time the pump is running even when they are turned off.
    Mar 2010
    Kansas
    12
    That is correct. So it is going pump - filter - solar - SWG - pool, unless the solar is bypassed. I'm guessing a check valve is going to need to wait until I go all PVC.
    In one posting I read that the clamps will hold a little better if the PVC is "roughed up" a little bit with some sandpaper. Do you think it would help?
    Intex SWG
    Nov 2009
    Indialantic, FL
    323
    thanks for the clarification - don't know why I couldn't see that.
