Results 1 to 9 of 9
Thread: Best way to add Stabilizer
    thomc21's Avatar
    May 2009
    Grove City, Ohio (Columbus)
    15
    I nearly am finishing shocking my pool and cleaning the debris off the bottom for the second time. (Switch for pool pump broke and had to get electrician to fix after I nearly got fried trying, but he did get the pool light to work for the first time since we owned the house!)
    What is the best way to add stabilizer to the pool? Last year I tried to sock method which took forever and this year I have a zero reading on my CYA. The owner of the pool store said mix in a bucket of water to make a slurry and add it to the skimmer.
    7,500 In-Ground gunite / marble plaster. VS-3050 & VS+SVRS Variable Speed Pump. Rainbow-inline chlorinator (not even used for vacations). Pentair 520 cartridge filter. Paramount Clear O3 generator. SunTouch Controls. Pentair Legend Platinum.
    22,553
    Re: Best way to add Stabilizer
    You can add it to the skimmer but it still takes the same amount of time, you're just not looking at it. It's hiding in the filter. The reason we recommend the sock method is that in case you need to clean or backwash your filter you don't lose a great deal of your CYA before it has time to dissolve.
    The fastest way is to use liquid but that's crazy expensive most of the time.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Some have done it that way but note that you must keep the pump running so it doesn't sit in your equipment and you must not backwash for a while or it will go right out the hose. Either way, sock or skimmer, it won't show up on the tests any faster - the skimmer method doesn't dissolve CYA, it shoots the undissolved content out the return to sink to the floor. The only faster method is the newer and much more spendy liquid
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    thomc21's Avatar
    May 2009
    15
    Thanks! Should I make it closer to 40 or 45 instead of 30 because of vacuuming and backwashing?
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Ah I see great minds think alike but one of us types faster (I'm on my Blackberry thumb typing)
    You won't see your true levels for a while yet so plan to add the recommended amounts on the pool calc but not more. You can always add more as needed without any hassle but too much can be a headache which can require more chlorine or draining wateR
    I found a lingere bag in my laundry room (to put women's unmentionables in and throw in the washer). I throw my stabilizer into it, tie it off with a rubberband and then massage the bag in the water until the stuff has dissolved. I tested my water after 3 days and bingo...had CYA.
    26,000 Gallons in ground with spa
    SWG
    Jandy equipment
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    572
    I prefer the liquid, althought it is more expensive. I've bought the liquid off Ebay for a reasonable price. Or, if you do a google search, there are also some websites that are good as well.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    May 2009
    Trenton NJ
    497
    can you swim in the pool while adding stabilizer? My water looks good but needs more cya.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Quote Originally Posted by ethany
    I do. I use the sock in the skimmer method.
    South Florida. 20,000 gallons; 16x35 rectangular gunite; Pentair Intelliflo VF Variable Speed Pump; Hayward cartridge; Aqua Rite SWG. Dolphin Oasis Z5 Robotic Pool Cleaner; Kopec 540sc Electric Heat pump pool heater; Pool built in Spring 2004.
