Thread: DPD Powder
    Guest
    DPD Powder
    Can DPD powder (perhaps the concentration) change over time.
    I shocked my pool on opening and the pool stayed at shock level despite being very green for 3 hours (before hiting the sack). Pool looks better in the morning. I didn't test before heading to work so no numbers besides last night -
    CYA - 45
    PH - 8.2
    FC - 17
    Always a distinct possibility I am doing something wrong...
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: DPD Powder
    If the water turned pink, it should be fine. Count each drop of R-0871 as 0.5ppm if using a 10ml sample
    Guest
    Re: DPD Powder
    It did go pink.
    Thanks for the quick reply! TFP is the best!
    30,431
    Re: DPD Powder
    Yeah, the DPD powder will stay good for a while....it will start to turn darker and darker from almost day one but as long as it turns the sample pink/rose, the test is valid.
    You didn't ask but you need to get your pH down.....sooner rather than later
    Guest
    Re: DPD Powder
    PH is tonight.
