Thread: How much psi should i be running on my filter?
    I have a hayward s244t witch has a maximum psi pressure of 50.
    My filter runs at 45 psi is this normal,i can't remember if i use to run at 25psi or 45 psi but i think i use to be at 25 psi 5 years ago when my pool was new.
    Thanks
    42,000 liters inground pool
    swg aqua rite
    Hayward super filter sand
    Vinyl lining
    Haward 1.5 hp pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: How much psi should i be running on my filter?
    No, 45psi isn't normal. More than likely you have a bad gauge. 45psi is what you'd see if the returns were completely blocked.
    Quote Originally Posted by JohnT
    Thanks My gauge does seem a little old and it seems to maybe have a bit of water in it.I'll buy a new one today and i'll repost the results.
    Thanks for the advise.
    swg aqua rite
    Vinyl lining
    Haward 1.5 hp pump
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    Normal psi for us is 22#
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    Thanks you were right,it was just the gauge.Now with the new gauge i'm running at 19 psi.You just saved me from changing out my sand this weekend.
    Thanks
    swg aqua rite
    Vinyl lining
    Haward 1.5 hp pump
    SW Indiana
    9,199
    Quote Originally Posted by bats
    Thanks
