Thread: looking for Cartridge filter and Pump for AGP
    Janesville,MN
    10
    the pool I have is Intex 16' x 48" Metal Frame Pool and I am looking @ adding Cartridge filter and Pump to it since the one that came with wont handle adding a SOLAR BEAR SOLAR POOL HEATER any help would be nice.
    "Hard work pays off later, laziness pays off now!"
    Re: looking for Cartridge filter and Pump for AGP
    I'm using an intex 8111 (swg plus 2000gph pump) with my solar bears - works great, but I have the panels mounted near ground level which makes it easier on the pump than what would be needed for a roof-mount setup.
    17' x 25' x 48" Laguna "Portable" Pool (~12,000 Gallons)
    Intex 8111 SWG, Pump, and Filter
    3 Fafco AGP 4 x 20 Solar Bear Panels
    Dirt Devil "Pool Boy" (Pool Rover Jr.)
    BBB and a SWG make my pool care really E-Z
    22,551
    jml hit on the big question, are your panels going to be on the ground or on the roof?
    Are you planning on getting a bigger more permanent pool in the near future?
    What have you looked at so far?
    I recommend going with the largest filter you can afford and a 2-speed pump. Either a 3/4hp full rated or 1hp uprated. I like the Pentair clean & clear combo's but they're only single speed pumps.
    Janesville,MN
    10
    ok I have done some looking around and I think I found something that will work
    S180T92
    Pro Series 18in. Sand Filter Sys w/Filter Control Valve & 1HP Power-Flo Matrix Pump & Base FREE but the pump is only 1 speed
    the pool this will be going on is 16' x 48"
