Thread: Spider gasket - I think
    Frustrating situation - inexperienced
    I have a Hayward Sand Filter S-244T with a Hayward SP 711 Vari-flo valve. Since opening the pool, I am losing water when filtering. My system does not allow me to see if there is flow through the waste line when I'm filtering. Last week, I took off the top of the multi-port and inspected the spider gasket which looked ok to me. I replaced the top and have continued to lose water. The system seems stable when the filter is set to recirc.
    Questions - Should I replace the spider gasket even though it looks ok? Could it be that I just need to lubricate the gasket to create a seal? Am I missing something else?
    Thanks in advance for guidance
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Spider gasket - I think
    Is there water running out the waste line while you are filtering?
    It's hard to know. I don't have a clear section of the waste line. There is a small glass bottle attached to the base of the multi port valve near the waste line but I can't tell if there is water flowing through it. I guess I should remove that bottle when filtering to see if there is flow into it. (duh)
    Well - I checked and lubricated the spider gasket. The filter drain cap was a little looose and leaking a little bit. The system is filtering without losing water through the waste line. Hopefully, problem solved. Thanks
    22,553
    Sometimes that's all it takes! Hopefully it won't come back.
