Thread: Can you use pool cleaner whiles shocking?
    Not sure if this is the right forum or not, but I'm sure someone will know. Rained like crazy yesterday and this morning we have cloudy water for the first time ever. Backwashed since the pressue was a bit high and have shocked. Can I run my navigator while the shocking is going on?
    16 X 32 Vinyl. Hayward aqua rite salt system, T -15 cell. Hayward H250 gas heater, Hayward 1HP superpump.
    Toms River, NJ
    Re: Can you use pool cleaner whiles shocking?
    AFAIK, it is not recommended as the high chlorine levels can affect parts of the cleaner.
    45,180 gallon 26' x 53' IG Vinyl, irregular shape. Hayward sand filter / pump. Polaris AutoClear SWG, supplemented with a Hayward Automatic Chlorinator (In-Line). Hayward 400K BTU heater. Paramount "turnover" system. Polaris 480 PRO cleaner.
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    We have used the pool cleaner (Letro Legend II) while shocking -thus far, no apparent adverse effects...(although maybe this is a case of I-don't-know-what-I -don't-know.)
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    baudilus is right. The cleaner won't just fall apart instantly or anything like that, but it will reduce it's lifetime.
