Results 1 to 14 of 14
Thread: Best Home Pool Water Tester
    What is the most accurate and easy to use home pool water tester for a chlorine pool? I am familiar with the chemistry of the water after two years of owning my inground pool. I am ready to save myself trips to the pool shop and start doing this myself. What does everyone recommend for an open budget.
    Sincerely,
    Quinn
    Dallas, TX
    24,000 Gallon Chlorine Pool
    In Ground Gunite
    Hayward Pro-Grid DE6020 D.E. Filter
    1.5 HP Hayward Northstar Pump
    Aquabot Robotic Pool Cleaner
    Taylor K-2006 Test Kit
    Mar 2010
    Spring, TX
    1,082
    Re: Best Home Pool Water Tester
    There are two kits that are recommend here, the Taylor K2006 and the TF100. You can get both from the site below. I think most people go with the TF100.
    http://www.tftestkits.net
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    The best way to test your chlorine is the FAS-DPD test. This is a drop count test with no color matching and the ability to test very high levels of both free and combined chlorine with an accuracy of better than .2ppm.
    It's available along with the standard Taylor tests for pH, TA, CH and CYA in the Taylor K2006, and the TF100 at TFTestkits.net, and as a standalone test in the Taylor K-1515-A
    The Taylor Complete K2006 looks great. Has anyone tried AquaChek strips and compared results to a liquid test?
    Sincerely,
    Quinn
    Dallas, TX
    In Ground Gunite
    Feb 2010
    Houston, TX
    271
    Strips are just too inaccurate/inconsistent for maintaining water chemistry. IMO, I think I speak for the majority here when I say strips are VASTLY inferior to a good drop based kit.
    Either the TF-100 or the Taylor K-2006 would be a great choice!
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Most strips give you such a broad range of answers that we find them to be nearly useless. And, the way my strips were labeled led me to think my water was in acceptable ranges when it was not.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I just bought a TF100 kit a few weeks ago and like it, the Taylor K2006 and the TF100 are almost identical, they both use taylor chemicals. The K2006 has more professionally looking packaging and all chemicals in the same size bottles, the TF100 being from a small operation looks like it is packed in a cheap plastic tackle box, but contains varying sizes of the chemicals to meet real world needs (more of the chemicals you need to have more of, when you have a test that takes 3 drops a A and 20 drops of B, it makes more sense to have a bigger bottle of B)
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Quote Originally Posted by Isaac-1
    Psst...it is a plain old Plano Tackle box...but we love it and it works well.
    Dave the owner of TFtestkits.net and this website (TFP) is hands down one of the best consumer friendly operations you will deal with...period.
    The TF100 provides a much better value for your money than the K2006 IMHO. Better yet, if you envision needing to shock your pool often, get the TF100XL.
    It is money well spent.
    I love the little tackle box the TF100 comes in... I can move the dividers to arrange the bottles in any order I want. I put them all in the same order as the instructions, but it would also make sense to have them in order of frequency of use. I even have managed to fit my SpeedStir into the box by removing the dividers between the CYA test bottles and the reagent.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by samo615
    You.
    TF100XL. May as well get a speedstir while you've got the credit card out.
    Feb 2010
    Houston, TX
    271
    Quote Originally Posted by Richard320
    You.
    Can't argue with that, Richard. Very well put!
    For the price I paid for my TF-100XL, I should've gotten a Lifetime membership thrown in!
    Just kidding Dave, great kit and great price! Believe me, when we get a little more (back) on our feet, I'm breaking the CC back out!
    John
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by anonapersona
    Ditto here on loving the tackle box. I find it easier to locate the reagents than in a deep box. I'm leaving my little blue "daily" pH/Cl test kit in a more handy spot, sitting inside the poly measure cup, used for collecting the water. That is in a shaded window sill, inside. The big kit only comes out weekly or so. I'm a "micro manager" of the pool so chlorine never goes low and I test pH at least 4 times a week. BUT, when I go over to my friend's house to test her water I have to take special care to remember to put it back in the kit. I have her test pH and Cl every two or three days using my old HTH kit and some fresh HTH reagent I picked up for her at Wally's.
    BTW..... she and her DH are disabled and he has had several surgeries in past months. She's been so, so very busy with life she hasn't been able to spend much time reading Pool School. But today, she told me that she told one of his doctors about BBB and doctor was really interested and approving and is going to "check it out".
    She listened in on a phone conversation I had with her pool guy and I think it peaked her interest to squeeze in a little time to read Pool School.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Alrighty then.. guess I'm sold on the TF-100 XL with speedstir. I will have to recommend it to a couple of friends and family that are new pool owners if it works out well. Could anyone PM me a discount code?
    Sincerely,
    Quinn
    Dallas, TX
    In Ground Gunite
    Discount codes for the TF-100 test kit, and discounts at several other merchants, are offered to Lifetime Supporters of this web site. See CLICK HERE to Become a TroubleFreePool.com Supporter! for details.
