Results 1 to 20 of 20
Thread: Hard Piping AGP w/ light
    Jun 2010
    SE PA
    9
    First off I must say this is a wonderful place. I've already learned a ton and the community seems to be very friendly.
    I'm sick of leaking flex hoses after 3 seasons and plan on converting my AGP to hard piping this weekend. I've read the other threads on the subject and they have provided me with a lot of helpful information. I do however have a question on how people might tackle this.
    I recently purchased this light:
    It works great, really lights up our 24' oval. unfortunately it has the standard connect to a flex hose connection on the inlet side of it (on the bottom). It leaks no matter what I do with a flex hose - I just can't get it clamped tight enough. I even slipped a fernco over the flex hose and tried using that - it completely blew off when I started up the pump.
    Does anyone have any suggestions on what I can do to include this in a hard piped set up? Does anyone have a link to a better flex hose connection that I could clamp to this thing? If I can hard pipe everything but say a 1' section of hose that connects to the light...maybe that would work?
    24' oval AGP, cartridge filtration
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Re: Hard Piping AGP w/ light
    Is it the kind of light that replaces/fits your return? What is the size/type of the male end outside the pool that you are having leaking issues? Have you tried the flex PVC or just standard PVC to a union?
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Jun 2010
    SE PA
    9
    Quote Originally Posted by NWMNMom
    Yes it replaces my return. Its a 1 1/2" 'hose barb' end that the corrugated flex hose connects onto with a band clamp. When you say flex PVC do you mean like PEX piping? If so, I've never used it before. I'd like to convert it over to standard PVC but I'm not sure how to go from the 1 1/2" hose barb end to rigid PVC.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Here is a site with flex pvc http://www.flexpvc.com/ Does that barbed end screw out? If so just replace with appropriate pvc end to a coupler or union. If not a section of flex pvc with hose clamp to sched 40 and union so it can easily be removed as needed?
    Jun 2010
    SE PA
    9
    That site is great. The connection on the inlet of the light is a pool hose adapter as per them. Is it possible to use the flex pvc with a hose clamp? Am I better off getting PVC tubing for that portion then converting over to sch 40? I'm not sure how easy it is to force the flex pvc over the pool hose adapter...
    The less tubing and more hard/flexible pipe I have the better off I will be I think.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Quote Originally Posted by Bronco
    Yes, you can and should use a hose clamp in that situation or some folks use a cement. We like to be able to remove as needed. We have one on our pump just exactly like your situation going to the skimmer. We used a bit of silicone lube and it went on just fine with a nice tight leak free fit.
    Sched 40 is the recommended PVC type besides Flex PVC so its a matter of which is easiest for you and least expensive. We did get our Flex PVC at Lowes available in 6' sections. We have both and NO more unreliable regular corregated flex hoses that blow off or leak. Make sure to install plenty of unions to ensure easy removal and shut off valves so you can maintain without water loss
    ultra800_96's Avatar
    May 2009
    Pomeroy, Iowa
    225
    I have that identical light. I was upgrading to 1 1/2" hose & when I got to that fitting, whoops, it's only 1 1/4, not 1 1/2". So for the hose running to the light/return, I had to stay with 1 1/4". I've never had a hose blow off of that fitting. Are you sure yours is 1 1/2?
    12,900 Gal. 24' X 48" ABG Vinyl Round (17th Birthday)
    1HP Hayward Pump w/S180T Hayward Sand Filter
    AquaTrol RJ SWCG 2011 startup
    TFP Method since '09, TF100
    50ppm Borates, June '12
    Jun 2010
    SE PA
    9
    Quote Originally Posted by ultra800_96
    That might explain why I can't seem to get a tight enough seal with the clamps on it using a 1 1/2" hose. I'll look to pick up a 1 1/2" X 1 1/4" reducer then. Thanks for the tip.
    Aug 2009
    SW Wisconsin
    518
    if you want to do a nice connecton and still run rigid pvc right up to that light...you can do what I did..I ran my rigid 1 1/2" to about an inch of my inlet/light (I have the same one as you) and then used a Fernco flexible connector that was a 1 1/2" one side and a 1 1/4" on the other..and attached that to the light...works like a charm and no more flex hose.
    Dan
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Jun 2010
    SE PA
    9
    Quote Originally Posted by flyweed
    Dan
    Dan,
    That is exactly what I did and it has been working great for several days now. Thanks again to all for their advice.
    Aug 2009
    SW Wisconsin
    518
    glad it helped.
    Hard piped my plumbing and ran into the same issue with the same light/return setup. Good idea (wished I came up with it) =0) will try the fernco after draining and winterizing.
    10,000 Gallon 12x26 EZ Panel, Vinyl Liner, 1 1/2 HP Hayward Power Flo LX Pump (70 GPM), SM2300T Hayward Sand Filter, BBB Method....nuff said!
    Jun 2011
    Northern Maryland (near Delaware)
    170
    Are the fernco adapters able to be used with SWG's? Also I realize it is only 2 clamps but is that defeating the purpose of hard plumbing? I am looking at possibly using this plus it would cut down no vibration I guess. Also the light at least mine is a slight offset angle, is flex pipe acceptable? Lastly if I am going SWG should I just toss the chlorinator? or Pipe it in with with shutoffs around it for a backup? Am I overthinking this?
    15'X30'X52" AGP AquaSports Grande Buttress Free (10,620 Gallons), Hayward Dreamline S190 W Zeobrite, 1.5 HP Hayward PowerFlo LX, AquaLuminator Light+ fountain attachment, Pool Rover, Tf-100 test kit, Speed Stir.
    22,553
    The problem with Fernco fittings is that they're not designed for pressure applications. Use at your own risk!
    Real flexible PVC isn't a problem. I don't like the way it looks but it's designed for pressure applications and it's designed to be cemented.
    Jun 2011
    170
    Ok, I may look to see what I can cement onto the aqualuminator. I hate to cement it on and it leak, wife will kill me.
    thanks
    Jun 2011
    170
    I found some references to this Pentair Hard Plumbing adapter on this site as well as other(p/n79202900) It runs from $7 to $10 and supposedly is odd sized like the light. I am thinking of ordering this then attaching it to the light then a quick connect to it then a shutoff valve. That way I can undo the quick connect and shutoff valve. Stupid question do folks run their pipes above the ground or on the ground? I've seen both, if it is above how do you support it?
    22,553
    I run all my plumbing under ground even on an AGP. It looks neater and protects the piping.
    Aug 2009
    SW Wisconsin
    518
    why do you think you'd have a problem with a Fernco adaptor and a SWG? I've been running mine now for over 2 years using the Fernco AND a SWG and have ZERO problems with it. It continues to be a good, solid, watertight connection. (which can be easily removed if need be)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Hey flyweed, what swg do you have? I have the intex and am using the fernco to attach to it because of it's not uniform threads (I will eventually replace with another solution). Keep in mind, the fernco specifies a maximum test pressure of 4.3 psi and is generally made for dwv applications (non pressure), so use at your own risk. The shielded version is probably better than the non-shielded, but requires the adjoining pipes to be the same diameter.
  20. Back To Top    #20
    Aug 2009
    SW Wisconsin
    518
    I have an Aussie built "CompuChlor" self cleaning SWG...and it works great. I know that Fernco fittings are not rated for pressure, but it is working flawlessly now into it's 3rd season. Now, it may not last forever, but that's ok...when it "dies" I'll just replace it with another one.
