Results 1 to 11 of 11
Thread: Pentair Intellibrite light Controller
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    Received my new Pentair Intellibrite Light controller model # 600054 to replace my manual light switch, however I cannot get it to work. There are 3 wires, a black (hot) , a white (neutral) and a red wire wire which from what I can tell is used to connect to the optional transformer for the landscape lights. My light is 120v. When I connect it the green light switch illuminates when turned on and the light for the recall and hold switches illuminate, however the pool light does not turn on. After fiddling and double checking I still could not get it to work so I put in my regular wall switch.
    This seems very simple to wire, I am thinking that I do not know how to use the switch.
    Can someone out there who has experience installing this switch please tell me how to connect this switch and the correct sequence to turn on the light
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Jul 2009
    Shawnee, Kansas
    92
    Re: Pentair Intellibrite light Controller
    I am by no means an electrical expert or anything, but I know for my light, it takes a good minute to 'warm up' and to show in my pool. Mine is a fibre optic light, not sure of the brand. Could that be your case? I also know that once I shut it off, I am supposed to wait 5 minutes before I turn it back on to allow it to reset itself. Just a thought.
    And again, I am no expert, I shock myself plugging in the toaster....
    Matt
    20,000 gallon, sand filter, IG vinyl
    White, black, and ground on the controller should connect to white, black, and ground coming from the circuit breaker. Then, white and ground from the light should also connect to white and ground from the circuit breaker, but black from the light should connect to red from the controller.
    There is a drawing on page 6 of the manual that shows the correct connections. The only thing to keep in mind is that they assume that black from the light is connected to red in the junction box, and then red connects to red at the controller. In many installs, black from the light will connect to black at the junction box, which still needs to go to red at the controller.
    Since you have a 115 volt light, ignore the comments about the 12 vac transformer.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    I have no red wire in the junction box. All I have is a white, black and ground wire.
    Quote Originally Posted by Brentr
    Right, that is what I was trying to say. Connect black coming from the light to the red wire from the controller.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    Okay I will try that when I get hm tonite.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    I spoke to the Pentair Tech support and the person on the other end did not even know that they made a separate controller. After she found it in the catalog she had to talk with her supervisor. She informed me that I did not give it enough time for the light to come on and that I should give it at least one minute after turning the switch on. Has anyone ever heard of this?
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    Thanks to all for your help. I eliminated the first switch and ran an extra wire which I connected the red wire behind the controller to the black wire of the pool light. Tripped the GFCI and the power to the controller went off. I am very pleased with this controller and now can fully utilize all the light colors and light shows with the push of a button.
    Jun 2014
    PHOENIX ARIZONA
    1
    Jason i will be using your advice and wiring a pentair intelibrite light controller to a wpc 2 fiberstars box.
    Will the remote controller still turn the light on and off?
    I hope once i manually set the color i can still use the remote.
    Nov 2016
    Tampa
    2
    Quote Originally Posted by JasonLion View Post
    Thanks Jason, I understand this is an old post and I most likely just don't fully understand electrical wiring. Could you please clarify for me.
    My pool light is powered directly from the main circuit breaker. From the pool junction box, my pool light switch wire runs to a house switch housing that has two light switches and the pool light switch. The pool light wire has three wires, black, white, and ground.
    My Pentair Intellibright switch has three wires, black, white, and red.
    How should I make this connection?
    Controller to pool wire:
    White to White
    Red to Black
    Black to ?
    Hopefully I made this as clear as possible.
    Henry
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    I am posting a pic of the wiring behind my intellibrite controller in the hopes to help others.
