Results 1 to 10 of 10
Thread: polishing water or am I just too anal??
    Aug 2009
    SW Wisconsin
    518
    Hi all...well I've got my pool open..chems are in check..TA is still a touch high..but otherwise all levels are good...temp is 84F..FC 3, pH 7.4, CYA 70
    my water is clean and clear..I can see small kids toys laying on bottomr of pool...but my water is still a little "blurry" when I swim underwater...I can't see really clear when I open my eyes. is there anyway to polish my water yet, and make it completely sparkly, clear?? or am I just being to anal??
    Dan
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: polishing water or am I just too anal??
    Get a DE filter.
    Or try adding some DE to your sand filter. Search it, I know there was a thread about a week ago on it.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    The blurriness has to do with the difference in pH between the water and your eyes. Try wearing swim goggles, it should be clear then. If it's still blurry with the goggles you could try the DE trick.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    There are two different kinds of blurry. When opening your eyes under water, the refractive index of water isn't what your eyes are used to (air) so things can be a little burry. Then there is what the water should look like from above, which is crystal clear, almost like the water wasn't there at all.
    Your FC level is right on the low end for your CYA level. Try bumping it up to 4, and try the DE trick that Richard320 suggested. That should get the water sparkling.
    Jul 2007
    Rockville, CA
    99
    Increasing your filter run time may also add sparkle to your pool. Are you currently running your filter at least eight and-one half hours with your water temperature at 84 degrees?
    20K inground gunite w/ Aqua Logic automation and chlorination Sta-Rite 400 K natural gas heater and cartridge filter 2 HP pump 1.5 HP spa bubbler for spillover spa 1 HP dedicated Letro Legend cleaner
    H2O: two parts Heart and one part Obsession. ~Author Unknown
    Aug 2009
    SW Wisconsin
    518
    I run my filter 24/7...it has 200 pounds of sand in it...can I add DE on top of that? and how much?
    The water is crystal clear looking at the pool from the deck..it's just swimming in it with eyes open..it's blurry.
    Dan
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    The water acts as a corrective lens due to the different index of refraction from air. I'm blind as a bat without my glasses, but I can actually see fairly well under water.
    I use the brand name on my main drain as a gauge of water clarity. When I can read it clearly standing on the deck (more than 14' away, with ~8.5 being through water), I know I'm good
    Aug 2009
    SW Wisconsin
    518
    so I guess I am just being anal huh???
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yup.
    FWIW, I just asked my older brother (doctorate in optical physics) this exact question over the weekend, and got the same answer Jason gave. He said if your eyes were really bad, in just the right way, then you'd be able to see perfectly underwater without goggles. I guess JohnT is pretty close...
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Quote Originally Posted by flyweed
    Nah...just a mild case of sparklypoolitis
