Thread: Reliable Pool Service in NoVA
    CUTiger78's Avatar
    May 2009
    Got any ideas?
    I was lucky to find Cox Pools when I moved here in 1994. Rob was a reputable guy, hired competent staff, and stood by his work. Sadly, he moved on to bigger and better things a few years ago.
    Since then, I haven't found a competent, reliable, and reasonably expensive outfit for openings, closings, and occasional maintenance. I've tried a few, too.
    Anyone got any recommendations in the Northern VA area?
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    PVille's Avatar
    May 2009
    Re: Reliable Pool Service in NoVA
    Give Elmer Calix (owner) at Affordable Services a call 703-986-6919. He came highly recommended from the company who installed my pool. Very knowledgeable and very professional.
    I had a leak when I opened this year. He was able to locate the underground leak and then repair. I had a cracked return and he was able to dig down next to my concrete, tunnel to the edge of the pool to do the repair and then backfill everything. All the work was completed the same day.
    In ground 15 X 33 10,400 gal. Fiberglass
    Two Returns, Two main drains, One skimmer
    Aqua Logic SWG, Hayward TriStar 1.5HP
    Hayward C3025 (325 sq /ft) Cartirdge Filter
    Solar Heater (Details at
