Thread: How does taylor k1004 compare to k2006
    Hi
    I just bought a simple test kit taylor k 1004 witch tests for fc ph and alkalinity.Does a k2006 test fc ph and alkalinity the same way?
    Thanks
    42,000 liters inground pool
    swg aqua rite
    Hayward super filter sand
    Vinyl lining
    Haward 1.5 hp pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: How does taylor k1004 compare to k2006
    Quote Originally Posted by bats
    Hi
    Thanks
    pH and TA are same test exactly. FC is completely different.
    Your kit can't measure FC accurately above 5 ppm (some say at all), nor can it tell you CH or CYA levels. CYA test will tell you how high you need to maintain FC. CH test will warn you if you're going to etch or scale your walls.
    Still, what you have is better than test strips or trusting the pool store. I think you'll end up happier getting a better kit. I bought what you have originally. Then I bought a better setup. Then I bought the TF100. You can use your vial and reagents for testing even if you buy the better kit.
    Quote Originally Posted by Richard320
    Hi
    Thanks
    Hi here in canada the k2006 costs 160.00,but i'm sure that i'll end up getting it with time.
    I just wanted to see how well it works for testing these differn't parameters and i'm already impressed.
    Thanks
    swg aqua rite
    Vinyl lining
    Haward 1.5 hp pump
