Results 1 to 12 of 12
Thread: Hello pool people!
    Jun 2010
    Elkridge, MD
    104
    Hello pool people!
    I'm Rob from Elkridge, MD. My wife Stephanie and I moved into our house last fall, and are only opening up the pool now. The previous owner had been sick, and the house took a long time to sell after his passing, so the pool water had been sitting in there covered for years.
    Through research, and also some trial and error, I'm pretty sure the water is just about ready now...it's still a bit cloudy, the pH has been harder than I expected to keep high enough (even with alkalinity in the acceptable range), and I still can't figure out how my vacuum is supposed to work (it came with the house so I don't have an instruction manual...neither the vacuum or the suction thingie it plugs into are threaded or anything...it just floats right out unless someone holds it there!)
    Anyway, I am looking to learn a lot here, and get to know many of you. I am going to use regular pool chemicals this year, but possibly switch to BBB next season once I learn more about it and understand how many trips to the grocery store it would entail.
    32 x 16 20,000 gallon inground vinyl. Pool Genie filter. BBB seems to be working well so far despite high CYA. Aquabot Turbo T which I adore.
    22,543
    Re: Hello pool people!
    Welcome to TFP.
    Sounds like you have a suction side cleaner. Your vacuum plate is designed to be held into place by the vacuum created by the pump. I place mine in the skimmer while the pump is running. You'll need to learn to fill the hose up with water before plugging it into the plate.
    If yours is not a suction side cleaner just disregard the above advice.
    Jun 2010
    Elkridge, MD
    104
    Thanks for the advice. I'll try to describe what I have as best I can...I'll take pictures if necessary, as I still don't know all the right terminology.
    About a foot or two below my skimmer is the suction valve thingie. That's where I try to put the vacuum, but it floats out eventually. I had filled the vacuum hose completely with water, so I don't think that would have been a problem.
    I can't feel a lot of suction at the valve, but I can feel the filtered water coming out pretty hard from the skimmer, so the suction must be adequate since there's no other water source (right?)
    And yes, before you ask, I did turn the filter back on before attempting to use the vacuum
    Apr 2009
    Northeast Ohio
    221
    I'm no help with the vacuum question, but welcome to the forum. I've learned so much since I've been here. It's amazing how much information is contained on this one site. If I have any advice to offer, it would be to get your own test kit (either the Taylor K-2006 or TFTestKit.com TF-100). You can see a comparison of them here. Even if you decide not to do the BBB method, you will learn so much about your pool water and what effect the chemicals from the pool store have, you'll be amazed at how much control you have over your pool.
    The other advantage is that with the results from either of those test kits, the moderators and experts on here can walk you through any problems you encounter regardless of the method you're using to care for your pool.
    Again, welcome and I hope you get that vac figured out. I'd be in serious trouble without mine!! As they say "pictures are worth 1000 words" and might make it easier to understand your setup.
    -- Pete
    32x16 ft Grecian rectangular vinyl pool 8ft on deep end - 19000 gal. 18" Hayward S-240 sand filter. 250K BTU Pentair MasterTemp heater. Hayward 3/4 HP Super Pump.
    Jun 2010
    Elkridge, MD
    104
    Thanks. I do have the Taylor K2006 test kit--I trust it works well, even though it doesn't usually give the results I'm hoping for There were a couple old test kits that came with the house--they seem to still work okay, but I'm glad I bought a new kit because it checks for things like calcium hardness and CYA, both of which were virtually nonexistent in the water when the pool was opened.
    Jun 2010
    Elkridge, MD
    104
    I have a whole bunch of questions...Should I just create a topic in Just Getting Started with all my questions, or should each issue be a separate post?
    I have test results and photos and everything.
    I'm going to go ahead and become a supporter right now, in anticipation of how helpful everyone will be
    Jun 2010
    Elkridge, MD
    104
    Just became a supporter, can't wait until my flashy new badge arrives
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Quote Originally Posted by ElkPool
    Sounds like a good idea. We love pictures!
    Jun 2010
    Elkridge, MD
    104
    Great. I'm going to wait until my upgrade goes through, because I think I need the extra space
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Once your status is upgraded, please post the pics. I suspect that you have an equalizer line in the skimmer (useless! stupid! ... ) which is no good for vacuuming!
    Once we know your skimmer setup, we'll be able to help with the vacuuming issues
    Luv& Luk
    -Ted
    Jun 2010
    Elkridge, MD
    104
    How long does it take for the upgrade? Is there anything more I need to do?
    Butterfly's Avatar
    South Carolina
    10,045
    It depends on how busy JasonLion is
    Feel free to send him a PM to make sure the process is in progress.
    You're done SLAMing when:
