Results 1 to 13 of 13
Thread: Best way to dig down a small amount to lay large pavers?
    Going to make a short (perhaps 10 feet long) 3' wide walkway from the deck to the pool with some 12-16" wide pavers from HD or Lowes etc.
    I obviously need to dig down to make a nice flat level surface but I don't need to go too far down with it. Is there a simple way to do this as I would think going at it with a shovel would be like doing surgery with a meat clever (not pretty).
    Just looking for your ideas.
    Thanks
    Greg
    27' x 52" Round Lomart Sandstone AGP
    ~ 18,000 Gallons
    Hayward S244T Sand Filter 300lb
    Hayward 1HP Matrix 2 Speed pump
    2" Plumbing - 50 Foot run buried 18" Deep - Widemouth skimmer and 1 return with eyeball
    Compupool CPSC24
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Best way to dig down a small amount to lay large pavers?
    how about renting a sod cutter?
    30,419
    or a roto-tiller?
    22,549
    or a roto-tiller?
    That was my first thought!!
    Apr 2010
    Buckeye, AZ 85326
    619
    I would rent a roto-tiller like duraleigh mentioned. Go a few inches deep, shovel out the dirt then put a layer of sand down to make a nice level compacted surface for the pavers.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    with child labor of course !!!!lol ......i would use a sod cutter !
    'If you can read this, thank a teacher -and, since it's in English, thank a soldier'
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    If the ground isn't too hard (packed clay) and we're only talking like 3 inches or so, and if there is grass you want to save there, I would chop all the way around it with a sharp drain spade type shovel. Then just get close to parallel to ground with that same shovel and poke/slide it under the grass squares you have already chopped out. Drain spade---------the other handy man's secret weapon.
    Mar 2007
    Ontario
    211
    If frost is an issue where you live, you will need a good base. If you don't get rid of the top soil
    you will get heaving from the frost.
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by haybird
    What haybird said.
    You need to dig, with a shovel, down at least 8 inches, preferably a foot. Then you need to add enough processed gravel to bring that back up to about 4 inches below grade. Pack the absolute dickins out of it with a hand held compactor. I mean really pack it. Then, get some 1x4's and some stakes. Form up the walk a little bigger than the 10 x4 (you said 3 feet wide, but it would look better 4 feet wide). Make sure the forms are level side to side and put about a little fall in the 10 foot length to drain water.
    Get some stone dust and level it off in the forms, about 4 inches thick. Pack it down and then screed it off with a 2x4 and pack it again. Lay the pavers on the stone dust. Get some edging and stakes to hold the walk then pack in loom (loam for you non New englanders), then seed or sod back. Thats the proper way to lay a paver walk.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Thanks for the suggestions everyone. Never really thought about the tiller or sod cutter.
    Greg
    ~ 18,000 Gallons
    Compupool CPSC24
    Dec 2009
    2,690
    While a tiller or sod cutter will do a great job removing the grass, I really cant stress enough that to do this job properly where the walk will look good, have no heaves, etc, you really must follow the directions I gave you. You really cant just lay pavers on top of the ground with a little sand underneath. It will not last and will not look very good.
    Well I actually had the pool installer use the bobcat to dig it down for me, it will need cleaning up & leveling as he only got the heavy work done. I didn't go to the extreme you gave me but I did have him go down about 6" and will fill in and level from there.
    ~ 18,000 Gallons
    Compupool CPSC24
    I went the tiller route a few weeks back when doing my own pavers. Home Depot rents a nice big one for $42/4 hours.
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
