Thread: How long before swimming after adding borates?
    Jul 2009
    Long Island, NY
    267
    I am ready to add borates using the boric acid method. After adding the boric acid, how long should I wait before letting the kids back in the water? I would like to add the boric acid either tonight (after the kids are done swimming) or tomorrow morning (while they are at school). If I add it tonight, should I leave the pump running all night?
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Re: How long before swimming after adding borates?
    Here's the answer Jason gave me.
    You can swim if the FC and PH levels are reasonable and the water is clear. If you are adding borates with borax and acid, they will probably throw off the PH for a few hours. It is best to give the borax and acid four hours to mix without swimming and then double check the PH before getting in. If you are adding borates with boric acid, you only need to wait about 15 minutes before swimming.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Jul 2009
    Long Island, NY
    267
    Lynn,
    Thanks for your response. I read a lot of old posts but did not see that one.
