Results 1 to 19 of 19
Thread: New Pool Owner in Northern NJ
    Morris County, NJ
    9
    What a great site! The breath of knowledge can be daunting at times. It's perfect for people who love soaking up knowledge!
    First off here are my results after getting comfortable with the TF100. I shocked the pool based a preliminary results since the CC was at 1.0 prior.
    FC = 10
    CC = 0.5 (I am thinking less because it was ever so slight)
    PH = 7.2 (or maybe less since I wasn't sure of the shading but certainly no where near 6.8)
    TA = 140 (not sure what I need to do to lower it)
    CH = 300 (Turned blue but are there supposed to be small blobs of pink or does the test require the blobs to turn blue as well. My first test I went to 350 to see if i could get rid of blobs )
    CYA = a little less than 30
    Anyways, just wondering what to do now besides a FC drop test tonight. Any suggestions besides that? Am I on the right track? Should I wait for FC to drop before using the pool? Do I need to add more chlorine? Namco by me is selling 6% gallons at $0.99. Is that good? Should I buy a lot?
    Also how can you tell the inline chlorine feeder is even working? I put pucks in and put the gauge at 3 a week ago and there are still 3 pucks. Also, would heating the water change chemistry? Haven't turned it on because I was afraid it would. Also it has been raining on and off? Is that something to worry about as well?
    Also I think I have a solar cover in the shed but haven't really opened it up. When should I be using it?
    Sorry for all the questions... When I bought the home the pool was closed already and never really took inventory until we had it opened. BTW, still bent out of shape because I felt like I learned nothing from the people who opened it. Also when the time comes does anyone recommend anyone who closes pools? I am thinking of doing it myself but I don't want to screw up the plumbing!
    Thanks again in advance!
    22K Rectangular (Bermuda) Vinyl IG Pool, 16x36
    Hayward Super Pump 1HP
    Hayward DE3600
    Hayward CL200
    Raypack 2100
    30,414
    Re: New Pool Owner in Northern NJ
    I'll answer a couple of questions...
    1. I would leave your TA alone for now. You may never have to adjust it even though it's a little higher than normal. Disregard the blobs in your CH test....it's a known interference and does not invalidate the test. Count your CH as 300.
    2. Do not count on the tabs to bring your CYA up unless you want to burn up a lot of tabs. I'd save them for when you go on vacation. Purchase enough CYA sepeartely to get your CYA up to around 50ppm.
    3. How does your water look? I am surmising it's very clear. Any signs of algae?
    22,544
    Sounds like you're off on the right foot.
    Get the overnight loss test out of the way before you worry about anything else.
    You can swim up to shock level for your CYA.
    You can read the Lowering Total Alkalinity article in Pool School. But I wouldn't worry about lowering it right now.
    If the bleach is 6% and gallons then I'd say that's a good price. Keep in mind that most of the time bleach is sold on 96oz containers not gallons. Still 99¢ isn't a bad price. Shop around!
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Morris County, NJ
    9
    1. I would leave your TA alone for now. You may never have to adjust it even though it's a little higher than normal. Disregard the blobs in your CH test....it's a known interference and does not invalidate the test. Count your CH as 300. Thank goodness (for now). Scratching my head on how to reduce without decreasing PH.
    2. Do not count on the tabs to bring your CYA up unless you want to burn up a lot of tabs. I'd save them for when you go on vacation. Purchase enough CYA sepeartely to get your CYA up to around 50ppm. Ok. Any nifty names I should be looking for? Or just go the pool store and ask for CYA?
    3. How does your water look? I am surmising it's very clear. Any signs of algae? Very clear. No signs of algae. Just have to keep skimming because of the trees.
    Hayward DE3600
    Hayward CL200
    Raypack 2100
    Morris County, NJ
    9
    Cool. Here is the link for anyone who is interested. I guess for Namco it is called Econoshock (which I believe is 6%).
    http://www.namcopoolstore.com/pdf/Flyer.pdf
    Hayward DE3600
    Hayward CL200
    Raypack 2100
    22,544
    If it is 6% I'd buy the limit. That is a good price!
    Morris County, NJ
    9
    Good morning! Just performed finished up my second reading for the overnight test.
    Prior night
    FC = 8.5
    CC = 0.5 (however slighter than the above reading)
    PH = 7.2
    This morning
    FC = 7.0
    CC = 0.5 (more slight to the point it is harder to tell when it turns color)
    PH = 7.2
    CYA = 35
    So do you think I need to bring up to shock level again since there is a 1.5 difference? Also after my first reading yesterday, I threw six 3" pucks in a floater and removed it right before my night reading. Would that have affected CYA? I figured I'd use them since I have a boat load of them and stop using them when I am at proper CYA.
    Hayward DE3600
    Hayward CL200
    Raypack 2100
    22,544
    With a loss of 1½ I'd keep shocking.
    Morris County, NJ
    9
    Okee doke! Continuing shocking! Btw, there wasn't a limit on buying the 6%. I bought 2 dozen and might go back and buy more!
    Quick question? How much does the tree dropping (i think it is pollen, greenish and brown) affect chlorine levels? I always wake up to a nice coating on the surface every morning. I guess I need to get use to skimming everyday!
    Hayward DE3600
    Hayward CL200
    Raypack 2100
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    The pollen doesn't have that much of an affect to cause the overnight drop...
    Morris County, NJ
    9
    Quote Originally Posted by frustratedpoolmom
    Cool! Thanks! Just making sure I am fighting the right fight!
    Hayward DE3600
    Hayward CL200
    Raypack 2100
    Morris County, NJ
    9
    Ok. I think I am well on my way now. Though I wonder if no FC loss is possible. I had a good feeling but didn't think it would be that good. I will test again tonight just to validate my results. Also I notice that other pool owners on the forum have been registering 0 CC. I am wondering if it is achievable for my pool. There is always an ever so slight hue change when I am adding the drops for that test. I guess it is different for everyone. Duraleigh, you weren't kidding about burning up tabs to bring up CYA. I am thinking it will take a month of the floater and chlorinator to get CYA up. Good thing I have plenty to burn up. I wish I got to the forum before buying the lot.
    FC = 10
    CC = 0.5
    PH = 7.3
    TA = 130
    CH = 300
    CYA = 36
    Thanks again to this forum. If anything I've learned is patience is key in getting an ideal pool (with a little elbow grease).
    Hayward DE3600
    Hayward CL200
    Raypack 2100
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Quote Originally Posted by jojijr
    Ok. I think I am well on my way now. Though I wonder if no FC loss is possible. Yep, it is. It just takes time. I had a good feeling but didn't think it would be that good. I will test again tonight just to validate my results. Also I notice that other pool owners on the forum have been registering 0 CC. I am wondering if it is achievable for my pool. Again, yes. It takes time. There is always an ever so slight hue change when I am adding the drops for that test. I guess it is different for everyone. Duraleigh, you weren't kidding about burning up tabs to bring up CYA. I am thinking it will take a month of the floater and chlorinator to get CYA up. Good thing I have plenty to burn up. I wish I got to the forum before buying the lot.
    FC = 10
    CC = 0.5
    PH = 7.3
    TA = 130
    CH = 300
    CYA = 36
    Thanks again to this forum. If anything I've learned is patience is key in getting an ideal pool (with a little elbow grease). Yes it is. I play a patient pool owner on TV. It's the toughest part of this whole thing. Just keep pressing on.
    Feel free to post your FC checks and additions and to what level you are adding throughout the day.
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    Morris County, NJ
    9
    Quote Originally Posted by poolgirl22
    FC = 10
    CC = 0.5
    PH = 7.3
    TA = 130
    CH = 300
    CYA = 36
    I just realized I wasn't very specific with my post. This past night I had 0 FC loss. I tested twice to make sure because I was a bit shocked. But what bothers me is I still have a very slight CC. < 0.5 CC. I guess I should test again tonight to validate anyway. And if it tests out ok tomorrow, I'll be more of a believer. I am with you on the patience! Murphy's Law always seems to get me though!
    Hayward DE3600
    Hayward CL200
    Raypack 2100
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    As long as your FC holds overnight you don't need to worry about CC when it is .5 or less, which is what you have. You can bring it up to shock level again tonight and do another overnight test if you want to double check, but you should be finished shocking now.
    Love TFP? Become a
    TFP Supporter!
    Morris County, NJ
    9
    Quote Originally Posted by zea3
    Very cool! I will do as suggested. Now I just need to work on the alkalinity but it seems like it is improving over time. Not sure what is doing it? The breezey days? (aeration). I just had a couple of questions.
    1. In filling the pool with more water, I am figuring I need more chlorine. Is there calculation for every inch of water added how much chlorine to add? Is it significant?
    2. Would a solar cover help with water loss? And would it also help with those stormy days when the more than usual gets in the pool? Might also help with the critters I find dead in the pool..
    3. Any suggestions on emptying the filter basket? I don't think I have much success emptying without the water pooling. The equipment sits below the pool from far away. There is a valve I turned to shut off the skimmer and and the other suction line but then it seems to still pool water (i am thinking from the filter maybe). Maybe I should take pictures and post?
    Hayward DE3600
    Hayward CL200
    Raypack 2100
    11,969
    A couple of inches of water shouldn't make that much difference that daily chlorine additions won't take care of. Just test in the evening and add it as you normally would. Yes, a solar cover cuts down on evaporation and UV destruction of the FC.
    Shut valves are my only suggestion - if you want to post a pic for some tips, that'd be ok...
    Jun 2007
    New Jersey
    653
    I also have a setup below water level. Besides the skimmer and drain valves, you should set your multi-port filter valve to Closed if you don't want flow out of the pump basket. Just REMEMBER to put it back to FILTER before restarting. Water will backflow through the return lines and the filter to exit the pump basket. I just let mine flow and don't close any valves if I am just cleaning the basket. It washes the crud out of the trap chamber and then I take the empty trap basket and bounce it up and down in the flowing water to get more crud out of it. Closing the top against the flow is no problem and it gets the air out of the chamber. But my setup is outside down grade from the pool so I don't care about a few gallons of overflow.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Jul 2007
    Northern NJ
    299
    Welcome jojijr. The price for the 6% is excellent! I will be stopping by my local namco to pick some up. Thanks for the heads up. I usually buy the 12.5%, but you definitely can't beat that price. I saw them when I went in to get my start up supplies. This is the first time I have ever seen the 6% there. I think someone has been lurking here and realized the sales potential....lol. BTW, namco calls the CYA "conditioner". I always buy mine there.
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
