Results 1 to 14 of 14
Thread: Neophite pool issues
    Ok, I wish I would have found this site a few weeks ago. I have a 3800 gallon summer escape pool, (not the blow up kind). I set it up a two weeks ago and tested. Given the numbers I added 8oz of dichlor and retested 24 hrs later, FC was zero, added another 8 oz of dichlor tested 12 hrs later and FC was again zero. So I tested the CYA it was zero. I'm using a HTH 6 way test kit from Wally World. So then I bought some HTH stabilizer and added one pound in a sock for the last week, tested again last night and the CYA still doesn't show up. I did clean my filter this weekend which maybe I shouldn't have done that. I also added about a pound of Arm & Hammer to raise PH and TA, which it did. During the course of the last two weeks I have added a total of 6 1" tabs in the filter. I live in ND so its not real warm here yet.
    I did go to wally world and buy two gallons of bleach.
    Here are my current readings:
    FC=0
    PH= 6.8
    TA= 80
    CYA= 0
    Should I go back and follow the beginners guide for seasonal/temporary pools?
    Thanks for the help.
    Intex 16x48 Ultra Frame
    5100 gallons
    Intex Sand Filter and Pump
    BBB Bliss Baby!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Neophite pool issues
    Is this the drop test kit or strips?
    How did you add the dichlor?
    That much stablizer should have your CYA over 30, plus the dichlor, plus the tablets....you should be seeing something...
    Drop kit, I also have the strips which I use for a quick check and it shows the same readings. I added the dichlor by sprinkling it in the pool and running the pump for 24 hrs.
    5100 gallons
    BBB Bliss Baby!
    11,969
    Do you have any more Dichlor? If you can, add another 1 lb of dichlor, predissolve it in a bucket and pour it in front of the return.
    yep, bought 5 lbs intially.
    5100 gallons
    BBB Bliss Baby!
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Since your CYA was at 0, your CYA may have been converted to ammonia by bacteria. If this is the case you will need LOTS of bleach (chlorine).
    At this point you want to stop using dichlor and trichlor (tabs). Dichlor and Trichlor add CYA, and based on what you have already added you don't need any more.
    You want to shock to a FC level based on the predicted CYA level given all the CYA, Dichlor, and Trichlor you added.
    Check out the links in my signature for How to Shock, FC/CYA Chart, and Pool Calculator.
    Remember, shock is a process not a product. If you do have the CYA->Ammonia issue you will need a lot of patience (and bleach).
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    11,969
    This is an Intex-type seasonal pool, that was filled with fresh fill 2 weeks ago, right?
    If you can't get the FC to hold after another Dichlor addition you should drain it and start over, it will probably be easier.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Quote Originally Posted by frustratedpoolmom
    Oops...missed that small fact I guess that's why FPM is the Mod.
    Disregard what I said about ammonia, but I think the advice still stands. "Shock with bleach." Something is consuming FC and you need to get in front of it. I am not sure that I would dump ~4000 gallons of water if I didn't have to.
    If I schock with bleach with a CYA of 0 should I shock for an FC of 10? This would be 79oz.
    5100 gallons
    BBB Bliss Baby!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yep, 10 is a good target. Keep testing every hour or so if you can, since that chlorine may get used up pretty quickly. Keep bumping it up to 10 til it holds there.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    You can have your CYA tested again...it isn't zero. Based on the CYA, dichlor, and trichlor you have added it is probably over 30. Sometimes it takes a few days for it to register on the test.
    Based on that you could shock to 13 and it will get you there sooner.
    Thanks for all the help and I apologize for more ?'s but how long do I hold it at 10?
    Also I was thinking of what may have caused this, when I setup the pool the weather changed and it was raining and windy, the cheap cover that was on came off and I ended up with a bunch of leaves and junk in the pool and was unable to clean it due to the weather for a few days. I have since cleaned it and now have a solar cover on it which keeps the junk out better. Any chance that would have caused this issue?
    Thanks again!
    5100 gallons
    BBB Bliss Baby!
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Quote Originally Posted by Britmandogs
    You should read the "How to Shock" post in my signature. The gist is:
    [list=1][*]Measure the FC level[/*:m:1sb3hwin][*]Add enough chlorine to bring FC up to shock level[/*:m:1sb3hwin][*]Repeat steps 1 and 2 as frequently as practical, as often as once per hour, and not less than twice a day, until:
    1. CC is 0.5 or lower;[/*:m:1sb3hwin]
    2. An overnight FC loss test shows a loss of 1.0 ppm or less;[/*:m:1sb3hwin]
    3. And, if you don't have a FAS-DPD test kit, the water is clear.[/*:m:1sb3hwin]
    [/*:m:1sb3hwin][/list:1sb3hwin]
    Thanks to all, nailed with some bleach and now FC is holding well. Once my cheapo test system is gone I'll buy the TF100.
    Thanks!
    5100 gallons
    BBB Bliss Baby!
