Thread: lost over 6 lbs of cya
    May 2009
    Trenton NJ
    497
    I started testing my cya last monday and found out it was 30ppm, so I put in 6 lbs 11 ounces of stabilizer (sock method) tonight i tested it and its 30ppm. So I lost everything to back washing, oh i just remembered we had a terrible storm last night and i had to empty gallons of water.
    I need to start over, the ironic thing is the water is crystal clear. My chlorine is only 2 ppm. Do I need to shock if the water is looking good or just add some to bring it up?
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: lost over 6 lbs of cya
    Just add some to bring it up, then do an overnight test.
    You shouldn't have to shock necessarily. If your CC is .5 or higher or the FC isn't holding overnight, then you should probably shock.
