Thread: Poo-Poo Accident today
    Hello All,
    My toddler had an accident in the pool. #2 and it wasn't exactly solid- if you know what i mean. Any advise on how high to shock? My CYA is 35. According to Ben's Best Guess Chart and the TFP Chlorine/CYA Chart I should shock around 12 to 16. Do you think that is enough for poo poo?
    FC 5
    CC 0
    pH 7.8
    CYA 35ish
    Thank You,
    26,000 gal Round Artesian. 2 speed Water-Way pump. Sand filter. Robo-Kleen. Pool-Skim.
    Re: Poo-Poo Accident today
    The recommended approach is everyone out of the pool, clean up whatever you can, and then shock level for an hour and a half minimum with no swimming. Overnight is better.
    This is a good explanation for what you are dealing with. ... ations.pdf
    Good Luck!
